D 15 axle noise..
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Topic: D 15 axle noise..
    Posted: 08 Jul 2010 at 4:14pm
my 15 has always made a loud growling almost vibration noise when in road gear. I originally thought it was the usual ring pinion noise because it goes away while coasting. Now I think it may be in the right side axle housing. Upon disassembly, the bearings seem tight and look good, but the brake drum is very loose on the axle shaft. Enough for me to think it may be the source of the problem. Is the drum supposed to fit tight on there? any other ideas? I suppose I could put it together and adjust the brake rod both ways..  BTW... it is a LOT easier to get this old girl apart than the WD 45!!
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2010 at 4:43pm
Yes it should fit tight. Lots of hammering to make it go in.
1968 D15D,1962 D19D
