De accelerator pedal on HD16
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: De accelerator pedal on HD16
    Posted: 29 Mar 2018 at 12:06pm
Hello forum friends.
Can someone confirm for me that there should be a Spring under the De Accelerator Pedal on my HD16. There are two holes, one under the pedal and one on the floor plate that looks like a spring would attach there. I took off al the floor plates to sand, stir and repaint and noticed it.
Yes I know its petty and insouciant but if a spring goes there I want to put one there. Nothing shows up on the parts manual.
Thank you
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2018 at 12:25pm
there are 2 different versions but as far as I know the only spring is just above the injection pump near the shaft that comes out of the hand throttle tensioner.  I hope to go pick one up in a few weeks, so cant say for sure
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2018 at 1:23pm
Thank you cal. I see what is going on.
This page was generated in 0.449 seconds.
