Allis B Hydraulics
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Topic: Allis B Hydraulics
    Posted: 27 Mar 2018 at 7:23am
Have a question about the hydraulic pump on my B built into the pto/belt housing assembly. Right now the little ram is off as it didn't come with one so it just has the hose end left open; never used it before so I have never had reason to bother with it. I turned on my pto and it just pumps fluid out the hose even with the handle down in the drop position but doesn't seem to be with much pressure. Do I just need to cap the port to get it to have some back pressure to recirculate into the housing or is the valve not closing all the way and I need to un-stick something? I don't need the lift on that tractor so I am fine with capping the port; I just didin't want to cap it if the problem is a stuck valve so I am putting dead pressure on the pump all the time but it doesn't seem to come out with much pressure which is where I wasn't sure on the needing some resistance to recirculate idea. I just want to be able to run the pto and pulley without pumping all the fluid out so I can use it to run my corn grinder display at shows. Thanks for any help.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 7:43am
I don't have any systems on my B so I removed the hydraulic pump from my PTO.  It was easy.  I had some 3/8 aluminum flat stock and manufactured a nice cover plate.  Made a gasket and painted it.  Really cleaned up the back of the tractor and the best part, no more leaks.  I kept the pump just in case.
Edited by BEK - 27 Mar 2018 at 8:02am
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 8:45am
If adjustments on control lever is correct you should be able to just put pipe plug on outlet  port to seal it and be good.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 9:26am
There ought to be details on the hydraulics in the shop manual.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 11:19am
The B & C pumps do not circulate. It either pumps pressure to the cylinder, or holds pressure, or lets pressure return to the housing.
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 9:57am
Thanks for the info. I will look at the adjustment to see if I can get it to stop and just cap it but if it has to come off from something sticking I may just make one of those plates; that looks really clean. Thanks
This page was generated in 0.040 seconds.
