WD-45 vs. MF 35
russt66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russt66 Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 vs. MF 35
    Posted: 19 Mar 2018 at 3:08pm
My neighbor wants to trade his Massey Furgeson  35 for my WD-45. Apparently, his granddad had one like it.
The 35 has a loader with lift and tilt bucket. Two valve remote hydraulics.
My Wd-45  was recently converted to 12v. It also has the three-point conversion.  Rebuilt carb, new coil, battery etc. It is in perfect shape with wheel weights.
I am giving up a little hp, but get a loader and live hydraulics.
Would you trade?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 3:09pm
I wouldn't.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 3:29pm
wow,  no way would I trade on one of those turds.   with the loader it will steer like a lumber wagon and unless it has a front pump the hydraulics wont be too woopie.   I don't like how you sit down low straddling the tractor,  but im am partial to orange
Edited by CAL(KS) - 19 Mar 2018 at 3:41pm
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 4:28pm
My father-in-law had a MF 35.  Don't trade.  Don't even look at it.Wink
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 7:05pm
I wouldn't. If you want a loader, find one for the 45 and learn to use the hand clutch. The 35 is a handy little tractor, but not with a loader
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 7:44pm
The only place you will gain is with the three point hitch, Massey three point hitchs are among the best, way better than a conversion on an Allis, position and draft control are top notch, other than that, as mentioned above, a 35 isn't much of a loader tractor.
bharper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bharper Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 9:19pm
My grandpa bought a new MF 35 Deluxe Diesel in the early/mid sixties and he and my dad only have good things to say about that little tractor. Dad said for its size it would do a lot of work. They also had a WD 45 and only had good things to say about it also.
If you search it on the internet, Massey Ferguson is still building the 35 diesel tractor in some part of the world, and has been building it since its introduction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 9:29pm
I agree with Ken. 3pt hitch is of superior design/use. Position control and draft control are nice to have. (But you can get WD45 3pt kits that use the traction booster, right?)
Looked up what bharper said, and I was really surprised! If I was in the market for a "new old tractor" I might would buy one.
Seems I also heard a company is building knock-off versions of the John Deere letter series 2 cylinders for those 3rd world farmers, but I haven't found evidence to back it up.
And yes, a 35 is a good utility tractor, but is a dog with a loader. Even with live hydraulics and if it has power steering, lift very much and your back wheels will barely be making ground contact, unless it's really weighted down back there.
Edited by CrestonM - 19 Mar 2018 at 9:34pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 11:00pm
Would you trade?
I'll bet he'd like to trade! If it was me the WD45 will stay at my place.
I think about you guys trying to hook-up to a three point hitch plow backing up and then pull forward time and again only to get mad just to get off and pull or push the plow around so the lift links will line up. As I back into a SC plow and not get off  one time to hook up. Well I forgot them little two bottom MF plows are not that heavy. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 5:00am
If the 135 in question, don't have PS, no way.  If it does, check fer leaks, in the PS system!
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 6:55am
I'm with Dave.  It would be a no go if no PS.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 7:11am
On the farm we had a Massey 235 and a 245 with loader. Both of them were excellent tractors. I'm not as familiar with the 35, but it would be a tough call.
If I wanted a utility tractor with a small loader, and maybe a bushhog to mow with, I'd pick the 35. The live hydraulic and 6 speed high low make it very nice to slowly mow around obstacles or slowly backup equipment into sheds and such. The granny forward and reverse is very nice.
If I wanted a "farm" tractor, I'd pick the WD45. I would not like a loader or to do a lot of forwards mowing with a 45.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 7:16am
I wonder if you could try out that 35 for a while first since it is your neighbor? Maybe swap tractors for the summer? Who knows, you both might want to keep what you already have.
Wink
I am a Russian Bot
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 7:42am
You didn't say if thre MF 35 is a diesel or not. My self if I wanted and needed a front loader with hrydrlic dump bucket I would trade in a new york minute.
I guess Guys here have never heard of quick hitches makes hooking to 3 pt Equipment just as simple or maybe even simplier as you can see the quick hitch to line up with the lift pins and you can buy one for the little ferggy for as little as $100 to as high as $500 depending what you want to spend.
I have it on my Kubota and find it easier than the SC on my D17.
As for power steering the WD 45 didn't in most cases come with it either so installing a front loader and plumbing for a hrydrlic dump bucket can be Just as costly operation. You would still be with out power steering.
I would buy one of thre many power steering kits on the market for the MF 35 if I found I was a woossss and couldn't turn the tractor.
I would then spend the time searching if I really wanted a WD /  WD45.
Tractor house this morning has 26 listings for a WD 45.
The MF 35 listing is 22 but only a couple with front loader in the USA.
Big smile   Al
Edited by alleyyooper - 20 Mar 2018 at 7:47am
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 8:05am
Take both to a sale and I'd bet the 35 will bring 2X as much as the WD45 so trade sell the 35 and buy another WD45 and then you'll have enough for a loader may PS for the new WD45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 8:10am
Sell the WD 45 and buy a 175 like this one.
Big smile         Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote russt66 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 9:50pm
Thanks for the comments. I have the 3pt conversion on the WD-45 already. So the hydraulics and loader is the only upside to the 35 on the trade. I'm only farming 7 acres.
Post Options Post Options   Thanks (0) Thanks(0)   Quote russt66 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 9:52pm
Both are gas
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 6:35pm
Yeah, that's what I was thinking.  Sure the WD45 has a lot more power, but if you're just using it as a utility tractor then the MF35 would be handier.  Like you said those small MF and Ford 8n tractors always bring high prices at consignment auctions, you never know what that Allis will bring.  My neighbor growing up had a MF TO35, he used it a lot for mowing, raking, and pulling hay wagons.  My neighbor now had several MF's including a MF 50 utility that we put a Paulson loader on.  It was kind of clumsy because it didn't have PS, but it wasn't any worse than a WD or WD 45 w/loader.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 4:14am
Pete, the 35 and the WD45 have nearly the same HP. I always thought the 35 was overpowered for its weight. The 35 and the 50 use the same engine. I've never driven a 50, but it seems that tractor's weight is better matched for the HP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 8:37am
Well...all factors considered, I think I'll change my initial opinion. If you only have 7 acres, farming with a 35 would be just fine. I could go into my long spill about the Ferguson system and its advantages, but I won't.
Considering both have 3pt, I'd definitely go with the 35, especially since it's just on 7 acres. I think that situation would call more for a utility tractor (35) than a row crop tractor (WD45). My great-grandpa farmed 300 with horses, moving to a Ford 9N, then in 1953 a Jubilee. The Jubilee was the last tractor he had, and he quit farming in 1983, so it can definitely be done.
I use my 8N on our 5 acres, and while I wouldn't want a loader on it, it does everything I throw at it and comes back for more.
I guess I just feel like a WD45 would be a bit overkill for your operation, BUT... it's always better to be overpowered than underpowered. However, if the 35 and WD45 are roughly the same HP, I think you'll be good either way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote russt66 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 8:53am
Actually I like the WD45 more than the 35. It sits higher and the seat and hand clutch feel like home. I do feel like I am straddling the 35. I was raised on a wd. My dad still has his WD which I can borrow or his Kubota 7040. I should post pictures of both wd and the wd45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 2:56pm
I've plowed all day sitting on a WD as well as on a MF 35. The 35 is more comfortable, without a doubt. The 35 has a six-speed transmission, but it's kind of a pain going between 3rd and 4th and back. The 35 deluxe will have power steering.
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 9:43pm
I didnt think a 35 had (live) hydraulic. I was thinking a 35 had to have to pto running to have any hydraulic operating. That being said im not sure iv never used a 35.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2018 at 5:57am
I'm not real familiar with the MF line, but the 35 I used had a dual stage clutch.. partway down stopped the forward motion but left the hydraulics and PTO engaged. All the way down disconnected everything. No PTO was needed for hydraulics.
Dave H View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2018 at 7:43am
If you are going to use the tractor for your hobby farm and the 35 was in good condition, I would have done it yesterday.
I guess it depends on your condition/age also and if you are sentimentally attached to the Allis.
I don't do any tillage on my 5 acre ranch.  The 8N and D 15 II (both are restored) slumber under car covers in the barn.  I do my piddling with the JD 1026r
chuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2018 at 8:41am
I have a mf65 diesel been a excellent little tractor, been to a few auctions trying to buy a mf35 for my old man and they brought way more than a wd45, but then again that's around here and not saying there a better tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2018 at 8:55am
don't matter what colour the tractor is, if it ain't got PS, using a loader,even empty, is NOT fun ! Once I built a carryall for my D-14, the loader came off PDQ. Still sitting here on a trailer waiting for someone, anyone to take it away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2018 at 11:58am
i don't know if my MF is a 35 or a 65, don't matter cuz my azz don't fit down in the seat tub!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2018 at 12:06pm
Gits a bigger tub!
