301 exhaust manifold torque
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: 301 exhaust manifold torque
    Posted: 19 Mar 2018 at 11:35am
I looked in the op-manual and the "it" book and having trouble coming up with the correct torque on a 8010. Would 50 lbs be too much? Thanks Dave
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 1:02pm
aren't they 1/2" bolts? It seems to me the 426 using 1/2" bolts are at least 75 ft lbs. Torque them  down evenly in small steps. 25,50,then 75.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 1:19pm
The 8010 is the 301 engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 1:39pm
7/16" bolta
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 3:50pm
I know the 8010 is a 301, I was comparing, thinking the 301 used the same exh manifold bolt size. 7/16 bolts would torque to 44-49 on early ones with lock tab washers, and self locking bolts are torqued to 30 ft lbs on earlier tractors to 7000 per my IT since it's handy. Later book calls for 46 ft lbs on 7010/7020.
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 3:58pm
I'll give er 45 lbs! Thanks guys
