Discuss
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Topic: Discuss
    Posted: 17 Mar 2018 at 12:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 3:20pm
Looks rough, possibly cab fire by the darkened skins. Grill for radiator guard is gone but can be manufactured as many have dimensions. Worth asking why it just sits and if can be had on the cheap.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2018 at 6:42am
Runs. Or did. Been on that location for nearly 20 years. Industrial redevelopment. Evry time they sell a lot it gets fired up and it clears the trash. Down to one lot. I think its a 41. At least that's what an operating engineer coworker told me.
Edited by exSW - 18 Mar 2018 at 6:44am
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2018 at 6:44am
hard to tell from that far out but it looks like the FD40's that our stripping contractor has in our quarry.  maby 21C?
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2018 at 6:45am
Reads Fiat Allis on cab and nose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2018 at 7:55am
Probably a 31... Has the CUMMINS 1150 straight six with one stack.. 41 would have two stacks.. ..... the rear tank reminds me of the 31, and it had two air cleaners.... the 21C I believe had one..
31 would be about 425 HP and weight in the 50 ton range without anything bolted on the rear.  Blade maybe 14 ft wide and 7 ft tall ?
Edited by steve(ill) - 18 Mar 2018 at 8:00am
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2018 at 10:40am
Blade is quite large.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2018 at 7:54pm
IF you get close, see if the name CUMMINS is cast into the intake manifold. Should be a straight 6 cylinder.
