Off color question |
48ACWD
Joined: 06 Jan 2013 Location: Pennsylvania Points: 208 |
Topic: Off color questionPosted: 16 Mar 2018 at 9:32pm |
Buddy of mine is building a ford 7000 tractor to run in our stock series classes. He is putting in a 304 genesis motor but ran into oil pan issues. Wide front end attaches to the pan so tried using original pan from the engine that was in the tractor bolt pattern is the same but does not clear the balancing gear set that the 304 uses. Just curious to see if anyone has or knows someone that's done this swap before. Any info would be a great help. Thanks
DrAllis
Posted: 16 Mar 2018 at 10:30pm |
Curt Forrester from somewhere in Pennsylvania is the guy to talk to.
bsallis180
Joined: 29 Jul 2013 Location: Pennsylvania Points: 209 |
Posted: 17 Mar 2018 at 5:06am |
Chambersburg Pennsylvania google the store Forrester farm equipment and ask for curt if not available ask for Cory, Curt is on the road a lot
bsallis180
Posted: 17 Mar 2018 at 5:12am |
Tell me I thought the Genesis was named after the 70 series tractor and that’s only a 456ci 6. Cylinder?
48ACWD
Posted: 17 Mar 2018 at 7:38am |
Thanks guys, I'll give them a call and see what they say.
DrAllis
Posted: 18 Mar 2018 at 7:28am |
The "Genesis" tractor was generally a 456, yes. The 4-cylinder version of it was 304 cubes and had all the design features of the 6 cylinder used in the Genesis tractor line. The medium duty truck version of that 6 cylinder engine was a 474 cube displacement. Pre-Genesis engines were a 401 and date back to the early 1970's.
Acllss puller
Posted: 19 Mar 2018 at 4:56pm |
Hey Brett you making any upgrades on yours this year ? Ie 426 in it ! Lol
