D10 manifold
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: D10 manifold
    Posted: 16 Mar 2018 at 9:16pm
I need to drill and tap the holes that holds the muffler on. I think it's probably pointless to try to get the broken bolts out. How deep are the holes, or do they go all the way through? I think they would easier to tap if I drilled them all the way through, although this is probably not correct. I'll be putting bolts back in them so there shouldn't be a leaking problem.
I can probably do this with the manifold on the tractor, but I think I'm going to remove it. It has a new gasket, I just wondered if I could re-use it? Thanks Ranse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 5:48am
Exhaust gasket is probably toast, anyway, they get brittle after just a few hours of running.  I'd just get a sharp bit, and drill it still on the motor...Wink
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 8:52am
All that I have seen went into the manifold bore and were tapped.
