1953 WD 45 with Loader
Ak47nutter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ak47nutter Quote  Post ReplyReply Direct Link To This Post Topic: 1953 WD 45 with Loader
    Posted: 15 Mar 2018 at 6:32pm
I bought a 1953 WD45 with a loader it ran when I bought it I cant seem to get it running now. It sat all winter and now I want to get it running and get rid of it. I Need to rerun all the wires from the starter, resistor and I think the coil. Is it possible to smoke either the resistor, coil or starter by constant cranking. any help would be appreciated. thanks I will try to post pictures
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 8:36pm
Welcome,
And good tractor! We need some pictures too.
If its still cranking your probably OK! Its when it quits cranking that you start to have the problems!
I have let the smoke out of many wires!
Check if you have fuel and spark at the plugs.
Edited by Sugarmaker - 15 Mar 2018 at 8:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 9:22pm
Does it spin over good? Is it have fire at plug wires?
Need more info.    MACK
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 10:44am
Give it a shot of starting fluid, if it fires up then you have a gas problem.  If it doesn't fire then you have a spark issue.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 2:02pm
If it set all winter I would clean the points for a starter.
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 5:29pm
I had this exact problem with my wd45.  Only after cleaning the gas tank and carb, putting a new fuel line, new points, coil, ext.  I got it to fire and then not fire. I just about lost my mind.  Walked away for a couple of weeks and checked the points and they were burned like I left the key on.  So I went back got new points and same d@* thing....
 Long and short the ignition switch was not operating properly.  She was sometimes turning things off and sometimes turning everything on.  Put a new switch in and magic.....
The funny thing is I kept telling myself I should replace the ignition at the beginning...
The moral to this story is "Don't talk yourself out of your instincts. " Well most of them, anyway......  Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ak47nutter Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 6:17pm
apparently the pictures I took are too big anyone know how to fix that?
The tractor turned over strong then it started then I shut it off and tried it again and it would not fire. Then when I cranked it more it got weak then would not crank at all I thought it was a dead battery but when I put the charger on it said the battery was charged, I don't trust the charger. This was all before it sat. Does someone have a wiring diagram for the WD45. The goats trashed all the wires, little buggers. Would I be able to pick up a new coil and resistor at auto zone or is that a specific part for the WD45. The previous owner had the wires ran all willy nilly I had planned on redoing them anyway to neaten them up so they could not be ripped off. I will get new switches too. I plan on tearing into it first thing tomorrow morning, going to put the battery on the charger now.
Edited by Ak47nutter - 16 Mar 2018 at 6:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ak47nutter Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 7:03pm
I am reading 1.5 ohms on the external resistor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ak47nutter Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 7:15pm
can anyone recommend a coil that is available from napa, auto zone or advanced?
I took the coil, resistor battery and carburetor off I'm going to clean it tonite and then put it back in tomorrow morning before the stores open then make a parts run.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 7:37pm
I think I got a coil for a 57 Chevy truck. It'll need a ballast restor though. I believe I used a ballast restor for a 66 dodge. The dodge resistor is a nice ceramic one with mounting holes it was easy to both it right to the coil mount. Seams to me the points were also for a 57 Chevy truck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 7:44pm
Go here for wireing http://dueyschutter.freeservers.com/photo3.htmlid hookup your current coil and ballast check your point and see if it has spark
Edited by Dakota Dave - 16 Mar 2018 at 7:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ak47nutter Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 8:17pm
Thanks do you know what the resistance values are supposed to be for both?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 9:27pm
If I rember correctly the coil should be 1.5 ohms and the ballast should be 1.5 ohms to give you 3 ohms total of your running a 12 volt system. If you have a 12volt coil that says no external ballast required it should be 3 ohms. As long as your not pushing more than about 4 amps thru the points they'll last a long time.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 7:08am
Could be the resister is sending low voltage to the dist. or none at all. I don't see how they last as long as they do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ak47nutter Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 12:14pm
I replaced coil, resistor and battery now it cranks but it has no spark at the plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 1:30pm
Do the points & condenser
You do have electric to the coil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ak47nutter Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2018 at 2:04pm
I did the points and condenser still know spark. Could I have my wiring wrong ? Do I need an ame meter ?
Edited by Ak47nutter - 18 Mar 2018 at 7:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 8:59am
Run a jumper directly from the battery to the coil if you have spark now start looking at your wiring if not it's in your distributor. Are you sure the points are set corectly
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 9:26am
First thing, turn the ignition to the run position and check for battery voltage at the coil. If you don't have battery voltage there, you have found the problem.
 If it were mine, I would pitch the resistor. Buy a 3 ohm coil made for any 4 cylinder engine. The one I have on the 45 was on a shelf at Farm and Fleet and listed for a Volkswagen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ak47nutter Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 1:48pm
I will try that when I get home I just have toggle switches one for the alternator and one for the battery I was able to redo the wiring to what was on previously. I am going to add a key too it and Ana's an Ame meter like the drawing shows. I will test to see if I have power to the coil. Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ak47nutter Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2018 at 3:45pm
I Ran a wire from the battery straight to the coil and resistor and now I have spark. sprayed some starter fluid in the carburetor and it started sputtered ad stopped. this is with the gas on, I checked the gas line and it was not plugged up. I cleaned the carburetor when I started this project. should I clean it again?
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2018 at 5:57pm
Double check that ignition switch.  When my switch went bad I would get power to the coil and then It would start and then sputter.  Then it would repeat the process of starting and sputtering and then nothing.....   But in full disclosure I am a rookie when compared to most of the guys on the forum.  Steve
