serial tag not under throttle
JamieH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamieH Quote  Post ReplyReply Direct Link To This Post Topic: serial tag not under throttle
    Posted: 15 Mar 2018 at 2:59pm
so I checked for the serial tag below the throttle and wasn't there. what I was able to find was the numbers off the right rear that read "HD5B 5088" will these numbers help me to get the parts needed or will I need the serial numbers as well...thank you
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 3:03pm
HD5B is model
serial is 5088
5B means 60" gauge (track width)  as  opposed to 44" on 5A
and 5088 makes is a '49
Edited by CAL(KS) - 15 Mar 2018 at 3:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamieH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 3:04pm
that's good...now I have something to go off of. the owner told me it was either a 54 or 55 but apparently he was mistaken. either way manuals are ordered and a resurrection is soon to come. just need time from work to have opportunities to make it happen...thank you for your input, it is greatly appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 10:04am
between 1948 and 1955 there were some changes but the basic machine is the same - had a early one as well as my 1955 - a 52 and a 50 -the 5B i had was reallow SRL#.
 Many of the changes amount to minor improvements, hyd pumps , pin boss extensions, loader supports on arms , transmission gear / high speed reverse , or other such but basically engine and finals as well as undercarriage stayed the same
