Would a AC 200 pull a 18"ft AC 2500 disk
72AC200 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72AC200 Quote  Post ReplyReply Direct Link To This Post Topic: Would a AC 200 pull a 18"ft AC 2500 disk
    Posted: 14 Mar 2018 at 4:41pm
I'm trying figure out if my 200 would have a enough hp to pull a 18" 2500 or 2600 disk. I'm farming my grandmother place and she's got clay ground. I would be using the disk the for fall tillage.I was curious if this could be done or not. I know depending on the size of the disc/ blade will depend on what size of disk harrow I can use or is there a good general rule of thumb I could use to figure this out. I know these disk are a heavy disk. Right now I'm using a 13" ft JD RWA disk and that disk is to light for what I want to use it for. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72AC200 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 4:59pm
I do have a set of front Weighs and the rear tires are full of fluid
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 5:26pm
Grandpa used to pull a 18 ft 7 1/2 spacing ih 470 with his 200 with weights and duals
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 6:22pm
should work good' you don't haft to cut a foot deep. thank it will work once it's set wear you like it.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 7:38pm
You're not going to be able to go very deep. I would question if you're going to be happy with the job it will do. We used to pull a 21' 2500 series on 9" spacing, with an 8070 2WD, and it was a load for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72AC200 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 8:06pm
How good are the 2300 disk. I have been looking at one of those. I know I can pull a 20" ft.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 8:10pm
We pull a WHITE 18', 7 1/2" spaced disc with an XT 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 8:11pm
2300's are good disks, would be more suited for the 200.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 8:56pm
Back when our 16ft 2600 was new it was pulled with a 200 and its all it could handle as ive been told. Nieghbor has a 16 or 18 2500 behind a 7000 and doesnt have much trouble. Theres a little difference in weight between a 2500 and 2600.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 9:09pm
Go for a smaller disc. Pulled a 20' Krause with 190XT turned up. Didn't pull it very good and gutted tractor.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72AC200 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 2:52am
Is the Krause a heavier disk than the 2300.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 5:24am
It should, I pull one with a my 4020. You are only working the seed bed, not plowing with it and it would help if there are duals on the rear of tractor.
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 12:59pm
A 2600 is much heavier than a 2500.  You would pull an 18' 2500, but I would think you would need duals, especially since you have heavy soil.  We have heavy clay soil and some hills.  We have a 21' 2500, and often are running behind a heavy offset cutting disc.  We pull ours with our 220 w/ duals, our 8030 2wd w/duals, or our 8010 w/singles and FWA.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72AC200 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 3:08pm
How reliable are the 2500 disk and can I get parts for them still. What is a general rule of thumb to use for figuring out how much hp I will to pull it. I do have duals for the tractor to
Edited by 72AC200 - 15 Mar 2018 at 3:15pm
LB0442 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 7:51pm
I remembered reading this a while ago.  Had to look through the files for it.  It is advertising so you know, use your own experience and check with other farmers in your area.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 6:54am
neat chart
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 7:26am
LB0442,
Nice chart.  I've seen a lot of marketing materials from the 70's and that's the first time I've ever seen that one.  Thanks for posting it.
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 9:08am
First time ive seen that chart too. Its funny how it says 25ft 2600 for a 7080 but in the picture the one is pulling a 30ft
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 9:52am
I think a Krause pulls easier. I have a 26’ Krause with 20” blades and have pulled it behind my 7050 with single 20.8s. Grandpa demoed a new 2600 behind his 7060 and it wouldn’t handle it but I forget the size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 12:28pm
I used to pull a Kewaunee 1010 18' with 20" blades with a 190XT, dualled, fluid and weights, but still had to float it.  If I tried to pull it full depth it would PARK the tractor.  Disc called for 136 drawbar HP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 4:34pm
good running 4020 will run with that disc' W/ duels little nose weight. 4th later after it's set you can go up a gear
clarkscreek View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 5:24pm
That would be one fine 4020 to till anything in 5th. I have a set of JD 215 14ft discs and my 65 4020 diesel syncro is 4th at best unless I'm just scratching the tracks out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 6:03pm
Nothing intended here, just my opinion, id rather pull a smaller with disc, maybe 14 ft. at least your not pulling the guts out of the tractor all the time, AC designed these tractors for 75 % pulling weight at 5 mph ,,
Edited by DougG - 16 Mar 2018 at 6:09pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 6:06pm
A lot depends on the soil.
My Dad was always quick to remind me of the following story.
We needed a new set of discs. At the time, our biggest tractor was a 180. The local Massey Ferguson dealer demoed a set of 12' Massey discs, which the 180 handled well.
Dad ended up buying a set of 9 1/2' Bush Hog offsets from our Allis dealer (who he bought almost everything from).
I wasn't happy. I liked the bigger Massey discs better. Dad sent me out and watched as I took the depth pins out and threw them in the tractor toolbox. I pulled into the field at about half throttle in fifth gear and casually reached over and dropped the offsets into the sandiest field we had. I ended up thrown into the steering wheel as it killed the engine and shocked me! Those little discs were sunk right to the spools and there I sat.
They didn't cut as deep in most of our clay fields, but they still pulled much harder than the Massey's.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 7:13pm
I have a 17’ Crustbuster offset with 24” blades that will pull the guts out of a 200hp tractor. I use it to chop stuff up after cleaning fence rows. I think AC made a 3300 offset that’s identical to my crustbuster.
Edited by 7060 - 16 Mar 2018 at 7:18pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 7:24pm
Remember you want a handful of a disc. Too small you are tempted to go too fast and ridge.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 8:46pm
There’s a lot of variation in soil types and what your doing with a disk that makes your question tricky. If you following a plow prepping seed bed in sandy loam you should be fine. If your in heavy creek bottom clay following fall chisel plowing cutting 4” deep to cut the weeds out by the roots like I do some times it will be a load. I have a 18 1/2’ IH 496 with 22” blades that can be a load on my 8070 FWA. It’s not the ideal practice but sometimes it’s a wet spring and you have to disk deep and plant the next day. Good luck
This page was generated in 0.197 seconds.
