Allis C Wiring |
Post Reply |
redbirds
Bronze Level Joined: 12 Mar 2018 Location: East Tennessee Points: 18 |
Posted: 13 Mar 2018 at 6:53pm |
New member now looking for real advice on wiring my C. My first goal is to simply get some juice to the coil and see if I can hand start. In the alternative, I'd use the following diagram minus the alternator and lights until I get a mount adapted. I have all the components listed in the diagram and a volt meter instead of amp. Other than that, all there. Anything look out of sorts with this idea? Thanks -R
steve(ill)
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 82070 |
if you have a coil, then you need ---
-- one side of the battery grounded to the frame --other side of the battery has a power cable to an on- off switch --output of the switch goes to one terminal on the coil --second terminal on the coil ( out) goes to the distributor point. --the point is grounded to complete the circuit. which terminal on the battery and the coil you use as the IN and OUT depends on if you have + or - ground system... your choice........ the condenser in the photo below is normally INSIDE The distributor and will have its wire anchored to the point screw. Edited by steve(ill) - 13 Mar 2018 at 7:32pm |
Gerald J.
Orange Level Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11865 |
We offer a complete wiring kit if interested. Drop by our website and check us out.
Steve@B&B bb-customcircuits.com |
Post Reply | |
