Wd45 spark plug confusion
Nick m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick m Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 spark plug confusion
    Posted: 13 Mar 2018 at 4:46pm
I read a couple places autolite 295's are a good plug for these. It has champion rj12yc in it. The champions don't cross to the autolites. Look to be the same overall length and thread size, but definitely different from the hex down. Probably over thinking again but that's me. This is the one I just bought that's been sitting for 15ish years.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 5:12pm
had best luck with AC-45 or 46' them other plugs are not hot . them lawn mower plugs with cold spark don't work very good in the old tractors if your working it.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 5:32pm
Forget about those Champions and just put some Autolite 303's in.
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 6:02pm
I’ve had pretty good luck with the Autolite 295 plugs.
I don’t work them that hard either.
Ray W.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 10:05pm
Any thing is better than champion.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 11:14pm
mack ;; you hit it right on the head Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 1:01pm
I also use the 295's and they preform well. I also do not like Champions. I guess its like a Ford or Chevy thing?
 I drive Fords!:)
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 4:22pm
I just put a set of NGK B-4 in my B haven't used it much yet. I have 295's in the others.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 8:59pm
For at least a quarter century Champion tractor pugs have been junk. Their choice of ceramic is bad. When it gets a bit of carbon it from full choke starting it doesn't clean from running normally hot and the carbon really hurts the spark and the engine running. Its not Ford vs Chevy, it is simply an inferior product.
Gerald J.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 9:06pm
Champions have been a problem as far back as late 50s. Uncles disliked them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 9:41am
I think my dad must have had stock in Champion plugs. Thats all he ever used in the Allis WD series and the B. He would buy them a dozen at a time and go through them like water. J-8 is still stuck in my mind!
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 10:01am
Bought a CA 18 years ago that had Champions.  Finally changed them last year.  Worked well for the 17 years I used them........but I haven't ever bought any more Champions.  I was using Autolite, but have switched to NGK
If ignorance is bliss, than happy days are here again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 10:17am
Autolite 295's are the hotter plug. 303's are the colder plug. When our customer's ask me about what plugs to use, I tell them either Autolite's or NGK's seem to work quite well in AC Tractor engines. In worn not rebuilt engines, the hotter 295's work quite well. In newer engines or freshly rebuilt engines, the 303's work great, especially with a Battery ignition. Anything with a Mag, the hotter plugs (295) work great. The NGK B6 works great also...
Steve@B&B
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 11:09am
Go to Ebay, punch in AC45 and buy some of the old stock AC45 that abound there. Be careful as there are now reproductions AC45 sold there too. Never heard bad (or good) about the repros buy why take the chance.  No they are not $1.50 a piece but if you watch you can get them for $3-4 by the box full.  If your head has been changed and you need long reach the number is 45XL and they are much cheaper than 45 to boot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 11:14am
Like these
https://www.ebay.com/itm/8-Vintage-GM-AC-45-Fire-Ring-Spark-Plugs-J396/282848977777?epid=658263563&hash=item41db1ce371:g:UewAAOSwG1NahPjU&vxp=mtr
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 12:16pm
Like these
That's the cheapest I'v seen those in a good while,good buy.They would be mine if I was't already stocked up.
Edited by ac45dave - 15 Mar 2018 at 12:23pm
This page was generated in 0.050 seconds.
