DD grader drive chain
66impalarhd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66impalarhd Quote  Post ReplyReply Direct Link To This Post Topic: DD grader drive chain
    Posted: 13 Mar 2018 at 6:59am
Can you tell me where I can get new drive chains from.
My DD has narrow chain links that don't seem to be available.
The rollers are only 3/4" wide whereas standard chain is 1" wide.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 12:03pm
I ordered new chain a few years ago from a bulk chain supplier. I gave them the information on the chain from my parts book and they had similar chain in stock and I the new chain within a week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 3:39pm
I am not sure but I think that chain was identified by a number, #60, #80, etc.  plus pinch and number of links. I don't remember the number but it was listed in the parts book.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 5:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66impalarhd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 7:04am
Thanks for the info, I'll see if I can cross reference the Allis Chalmers part no.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 3:54pm
It is #90. I replaced both sides on our D.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 3:55pm
The number is stamped on the link.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 11:30am
http://files.minnpar.com/partbooks/MOTOR%20GRADER%20MANUALS/ALLIS%20CHALMERS%20MOTOR%20GRADER%20MANUALS/DD%20PM%20%2373110201.PDF
Looks like page 128
1 1/4 or 1 1/2 pitch  #100 or #120
Edited by Coke-in-MN - 15 Mar 2018 at 11:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66impalarhd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 4:22am
I checked the number stamped on the side of the chain link, it is 121.
It has an 1 1/2" pitch, but the roller is only 3/4" wide, which is not a common size. I think my only hope will be to try find NOS chain unless anyone has any other suggestions.
Standard 120 chain has 1 1/2" pitch but a 1" wide roller. This size chain is too wide for the double sprocket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 8:21am
Sounds like the deal with bicycle chain where pitch is #40 but chain is #41 that is thinner in width . Ran into that on both bicycles and overhead garage door openers that used chain.
 Use to find a lot of things like that at old military surplus places that handled vehicle parts or surplus military hardware - know for a steer axle CV joint for  my Pettybone loader I found one at a place like that over in Mpls - but most of those places are gone now over there as City is beautifying areas and putting up appt buildings and condos for yuppies
Edited by Coke-in-MN - 19 Mar 2018 at 8:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 6:28pm
Found this on google:
You might find it in the oilfield industry, saw 121-2 and 121-3 (double and triple) listed fer that...Wink
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 10:25pm
Coke, your link got sucked up some how by that vigi-link crap on here...  Maybe this one will work better.
This page was generated in 0.172 seconds.
