8070 tach
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 8070 tach
    Posted: 12 Mar 2018 at 6:50am
A friend of mine purchased a nice 8070. The tachworks correctly at idle,however as power is supplied beyond half throttle it pegs to 2500 rpm. Hour meter is working. Other than the possibility of a bad tach is there anything else that can cause this? Can the hr meter still be accurate?
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 8:23am
There is a pick up sensor next to the fuel cap between the frame rail and the engine block. I might be bad. It picks up the speed from the flywheel spinning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 10:48am
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 12:35pm
try adjusting it first.I think book said 1 turn out from contact.Plug/unplug connector a few times to help continuity.
Edited by SteveM C/IL - 12 Mar 2018 at 12:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 6:39pm
I unscrewed the sensor and it is not damaged. Appeared to be correctly adjusted. I measured across the leads and it measures 200 ohms. I was told this is within specs but I would like to verify. I screwed the sensor back in and adjusted it. The hour meter continues to work, however the tach jumps up to 1,500 upon startup, any throttle above that results in burying the needle to 2,500. With that being said, is there anyone that repairs these electronic tachs?
