314H with EZ VAC
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: 314H with EZ VAC
    Posted: 11 Mar 2018 at 8:18pm
I got the EZ VAC system working today.  Nice tool.  I picked up all my leaves no sweat!  Love this thing.  The 314 is working great now.  It has a charging issue though.  I've ordered a new voltage regulator.  I hope that's the problem and it's not the alternator.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 9:56am
How big is that engine on the fan? Maybe 5 HP? I have a fan housing and impeller that came from an old Jacobson mower set up I believe. I've been dreaming of doing something with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 3:33pm
'not charging' could also be 'bad' ammeter( some leak charge to ground) or a 'bad' ignition switch , again power 'leaks' off to ground due to corrosion....
seems nothing last 30-40 years any more !
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 4:11pm
Hub, that's a neat set up and a great save overall. Those vac systems are awesome!!Got this vac system year before last and absolutely love it.They make short work of the leaf project every year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 5:51pm
Charlie,
You are correct--5 hp B&S.  If you want pics of the set up, let me know.  I'd be glad to get them for you.
Steve
Edited by Hubnut - 12 Mar 2018 at 5:51pm
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 5:55pm
Ain't that the fact!  Thanks for the tips.  The ammeter dives when I hit the lights and moves back to 0 after they are off.  So I "think" it is okay.  I pulled the ignition switch and it checks out properly.  I'm hoping it's only the VR.  I really don't want to pull the engine for the alternator.
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 5:57pm
Dave,
Good to know I can still find the tubing.  I was surprised that the original set I got is still quite pliant and not at all brittle.  It really picked up the leaves and made a good mulch for my compost piles.
Steve
1940 B "Lucy"
1972 314H
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 9:11am
Very nice setup!
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 9:34am
I used to have one of those throw away Ranch Kings. It had a heck of a pick up and sling for a cheap stamped deck, so I bought the attachment for the deck and the hose. Then put a bank board on my home made yard cart and went to blowin silage Big smile.
 If the grass got ahead of me,I would mow it one day pick up the next.
 I usually don't mess with leaves cause they will blow into the field. Sometimes I mulch em to keep them from choking out what grass I have.
Edited by CTuckerNWIL - 13 Mar 2018 at 9:52am
