HELP 706 DRIVE AXLE
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Topic: HELP 706 DRIVE AXLE
    Posted: 09 Mar 2018 at 9:13am
I RECENTLY PURCHASED AN ALLIS 706 ROUGH TERRAIN LIFT. IT NEEDED A LOT OF TLC WHICH I HAVE BEEN GIVING IT THIS WINTER. I THOUGHT I WAS FINNISHED AND WAS CHECKING OIL LEVELS. THE DRIVE AXLE WAS REALLY LOW BUT WHEN I HAD PUMPED IN ENOUGH OIL TO SEE IT I NOTICED OIL RUNNING OUT BOTH BRAKE ROD HOLES. AFTER STUDYING THE PARTS AND SERVICE MANUAL, IT LOOKS TO ME THAT THE BRAKE COMPARTMENT RUNS IN OIL, AND THE SEALS THAT ARE SUPPOSED TO BE AROUND THE BRAKE CONTROL RODS ACTUALLY HOLD OIL IN AXLE ASSEMBLY. CAN ANYONE TELL ME FOR SURTE ABOUT THIS?
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 9:19am
Pretty sure you are correct, especially if the brakes seemed to work OK.
