oil
domseb0 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote domseb0 Quote  Post ReplyReply Direct Link To This Post Topic: oil
    Posted: 08 Mar 2018 at 1:04pm
You guys on this site always have the best info so here it goes. I have some older tractors in my fleet that have always used 30w oil for years but all my new tractors and skidsteers use 15w40, Dad always said never use multi grade in the old girls. What do you guys think ?? Thanks
WD45,Ford 801, Ford 1801, Farmall H, Case VA, JD790 case 1070,IH 3288, XT190, case 430/530/730 Massey 4709M
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2018 at 1:15pm
You might want to look back... this has been covered, I think in previous pages...maybe one of the experts on the site will explain how to search......................
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2018 at 1:41pm
the BEST thing you can do for the older tractors is use multi viscosity oils... THe thnner 10 weight end makes them roll over good in the winter and startup faster.. The 30wt on the top end is to keep the oil thicker as it warms up.. Most use 10w 30, but if you want to standardize on 15w 40 like the skid steer, I see nothing wrong with that............ If your old  30 wt was a NON detergent, then you might get some cleaning of the gunk in the motor with the new oil. Monitor the new oil and it if turns BLACK early, then change it out sooner ( once or twice).. some have complained about this, personally I have never had that problem.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2018 at 1:48pm
And covered.. and covered.. and covered... and..
Bottom line: Never mind what old shade tree mechanics have told you.
orangeman69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman69 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2018 at 6:30pm
I use 15/40 cen pe co diesel oil in all my gas and diesels including cars and trucks for the past 20 years with no problems whatsoever. even in the Wisconsin winters... and all our tractors are old..8n ford to a 8070 allis
d17,d17nfpuller,d-17IVdiesel,d19gas,d19diesel nf,d21seriesII,180,190xtseries III,200,210,7020,7060,7080w/8.3cummins,8070fwa w/8.3cummins,8550 185 w/322 original hrs.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2018 at 8:53pm
We use John Deere 15w40 in our farm equipment.  Works great.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2018 at 9:52pm
I think the lone exception might be the old Two-Stroke Detroit Diesels. Straight weight type was the only specified oil, at least the last I heard.
Lubricant Recommendation for Detroit DieselĀ® Two-Cycle Engines
SAE Viscosity Grade 40
API Classification: CD-II, (Note: CD-II is an obsolete designation replaced by the current API Rating CF-2)
Military Spec: MIL-L-2104D
Sulfated Ash: Less than 1.0%
Post Options Post Options   Thanks (0) Thanks(0)   Quote domseb0 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 6:53am
Thank you guys !!!!!
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2018 at 6:57pm
If it has a filter use a multigrade oil.
