Value of an A-C Electric Motor? |
Post Reply ![]() |
steelwheelAcjim ![]() Orange Level ![]() ![]() Joined: 06 Dec 2009 Location: Blissfield,Mi Points: 1257 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Mar 2018 at 6:10pm |
My local grain elevator just removed it from their feed grinding equipment, It's 25HP, 440V 3-phase. It is burned out. The supplier would not take it for a core and told the Managers to just scrap it. Is there any collector following for these? What is one worth just for looks? Just found it so i didn't have time to call the scrap yard for a quote. Any ideas?
Thanks. |
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8357 |
Really doubt it,,, I was working at AT T in St Louis a few months ago and they have a few AC electric motors running various stuff, they were installed in the 30,s , pretty neat
Edited by DougG - 07 Mar 2018 at 6:14pm |
Ken(MI) ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Lansing, MI Points: 619 |
Scrap motors are paying pretty good right now, other than that, used and especially burned up three phase motors aren't in high demand.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6072 |
A motor rewinding shop could probably get it back in operation for a reasonable price (considering replacement)... as long as the 'burned out' is in the stator (not the rotor). A set of bearings with shields, a good cleaning, and it'd go another hundred years.
I salvaged an AC 7.5hp 1800rpm motor from an old air compressor, it had some wiped-out bearings and boogered up shaft... a little cleanup with a file and some emory cloth, blew out the crud, put in new bearings, and mounted a toothed-belt on it, now it's in the belly of my Monarch 10EE lathe, driven by an Allen-Bradley 1336F varible frequency drive at up to 180hz, it'll really cut metal... |
Post Reply ![]() |
