? For electrolysis experts
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: ? For electrolysis experts
    Posted: 07 Mar 2018 at 6:48am
Would a golf cart charger work? It's rated 48 volts and either 13 or 30 amps (not handy at the moment). Acquired one last week and don't know if it even works. Figured if it would work, it could be dedicated just for that, instead of using one of my good battery chargers.
VFDfireman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VFDfireman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 7:00am
IMO more is not better.
I have an old 6/12 volt charger from the 60’s that I rebuilt. It out puts a peak of 5a at 12vdc and it works great. A cheapie solid state would work well too.
Your grid setup and how clean it is makes the most difference.
1954 WD45 Restored 2015
Current Project: 1953 IH R120 Pickup truck
CB
"It's better to be thought a fool than to open your mouth and remove all doubt."
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 7:23am
Try it since you have it and use a piece of scrap metal to test.  Now if the supply is giving it all it's got depending on what load it sees and you are heating the water up more than just a couple of degrees then you are over cooking it.  I also used an old 12 volt battery charger for mine and it worked fine but it was a slow process and I was just too impatient to wait a week for it to finish so I bead blasted most of mine.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 7:54am
Yes, it will work, however this is way over powered for what your trying to do. Along with the massive power consumption, this could kill you if you bumped the connections. I was given one from work about 15 years ago, couldn’t resist finding out if it would work. I quickly found that used like this it’s unregulated and will heat the solution enough to melt a heavy duty plastic container rather quickly. After listening to the noise and watching the violent reaction I decided this wasn’t for me. I know people have used everything from old welders on down, but you’re gonna get the same result, much safer with a plain old charger. I also question weather there would be any detrimental changes to the part due to the reaction happening so fast. If you have to try. This, please be very careful and don’t leave this unattended !
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
drobCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 8:37am
not worth the risk IMO.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 9:09am
yes, it'll work but it'd be better in a very large tub. The higher voltage allows the electrons to travel further, so the bigger the gap between piece and plates, the higher the volts you need.
Current controls the rate( how fast ) the process is. The higher the current, the faster the action.
For a 45 gal drum 12 volts is more than fine. If you need better action, add more plates around the tub.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 9:38am
Unless you have a several thousand gallon tank your going to be cracking water into browns gas ( hydrogen and oxygen) a highly volatile mixture.i recall door g that in chemistry decades ago a little spark and a big boom from very small amounts of gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 12:32pm
at 48 volts and working around water, your going to get shocked or electrocuted..... stick with the 12 volts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 3:23pm
I don't think my old charger ever showed more than 2 amps @ 12V when I was cleaning parts for Lena. I even did the stripped down block in a 55 gallon bucket. It took a while, but gives you time to do other things. I think my block spent most of 2 weeks in the water. Clean electrodes daily and skim off the scum on top. I also took it out and flipped it once and turned it in relation to the electrodes a couple times.
 It came out nearly as clean as a block that was baked and shot blasted.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 9:17pm
48v is too high for a small tank.  Current is determined by applied voltage divided by resistance.  Resistance is a function of the distance....
So... if you carried 5amps at 12v, you'll be whomping 20A at 48v.  Too much, and yes, you'll be getting shocked, and likely get an inside view of the Hindenburg Experience when the gasses decide to rejoin forces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2018 at 12:04am
Thanks for the info. Wanting to do the moldboard from my 53 plow.
This page was generated in 0.364 seconds.
