8070 Cankshaft problems? |
Post Reply |
randy
Orange Level Joined: 12 Sep 2009 Location: Illinois Points: 1187 |
Posted: 06 Jul 2010 at 5:56pm |
A mechanic told me that he had heard of crankshafts breaking on 8070s. I have never heard of this, has any body heard of this problem? I am doing a out of frame overhaul and just wondered if this is a problem? thanks Randy
DonDittmar
Orange Level Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2484 |
yOU KNOW, i HAVE HEARD THIS RUMOR ONCE MYSELF, BUT HAVE NEVER ACTUALLY SEEN IT. MAYBE DR. ALLIS WOULD KNOW
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
ORANGE FARM
Bronze Level Joined: 01 Jun 2010 Points: 43 |
I WOULD HAVE THE VIBRATION DAMPER CHECK. THEY DO GO BAD.WE HAVE THEM CHECK EVERY COUPLE OF YEARS. IF THEY GO BAD, THEY WILL BRAKE THE CRANK SHAFT.
smuggler
Silver Level Joined: 23 Dec 2009 Location: western ny Points: 325 |
I personaly have never broke a crankshaft. We turn between 6500 and 7000 rpms have ran it with the dampner and currently dont use the dampner. And have never broke one.
wayneIA
Orange Level Joined: 17 Oct 2009 Location: Waverly, IA Points: 268 |
What I was told by the local AC dealer was to make sure that the dampner is in good shape, and it is best to install new rod bolts since they are very prone to breaking on most of the 426 engines.
smuggler
I have taken alot of stock 426s apart with spun rod bearings and have never seen rod bolt failure.
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4526 |
When I bought my D-21, there was a rod hanging out of the block. The rod bolts that I bought from AGCO (after trying to source ARP rod bolts through my local speed shop) have ARP stamped on the head. That gave me alot of confidence. ARP bolts are much stronger than anything that ever came out of West Allis. |
smuggler
Well in my personal opinion rod bolts are usually not the problem its bearing failure. Which is a very common problem with the 426. spin a bearing rod grabs crank and sumthing has to give.
randy
i have new head bolts and rod bolts, lookslike this engine was run hot, radiator was pluged so i am doing a out of frame overhaul! Bearings looked good and crank looks good, mearured on high end of journal measurments.
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20970 |
8070's weren't known for breaking crankshafts....7080/7580's were. Be sure to have your crankshaft magnafluxed by someone who knows where to look and especially on the nose just ahead of the gear. The cranks with a "keyway" for the front pulley would crack at the keyway area. Anytime there is a broken crank AND a broken main cap, the broken main cap caused the crank to break due to no support. I had an F2 combine years ago with the little 4 banger that broke a crank with less than 100 hrs on it and there was a broken main cap next to the break on the crank.
randy
How do you check a damper, i emailed the mfg. and am waiting for a reply? |
Kcgrain
Orange Level Joined: 24 Sep 2009 Location: Wisconsin Points: 774 |
I wish I knew how all these "BS " rumors got started, was it a John Deere salesman or an IH rep, maybe some farmer whose cousins, uncles best friends hair dresser sister had one that broke, been with 426 engines for 35 yrs now, over hauled a bunch of them seen them clock 20,000 + hrs with moderate care, yet the only one I have ever seen personally come apart was one that had 5000 hrs on and had been repeatedly cooked for 2 yrs prior, when it finally siezed a piston and broke the cap off of the rod ( must be the rod bolt failure) and came out the side. Where does this rod bolt failure crank failure BS come from, it just isnt true. Have friends that run an est 1000+ hp on a super farm tractor on a stock AC crank, so a 170 hp is gonna break it or the rod bolts?????Pure BULL S**T . Reminds me of a farmer I met 3 yrs ago with a shed full of new JD equipment, and when he found out that I was an AC man he went on to tell me what junk they were he "said he had D-21 thru to the 7050 and they were nothing but junk and constantly broke down, I tried to ignore him for the first 15 minutes of his BS but finally couldnt handle it any more so I said well if they were so prone to failure what was failing the engines, his answer was no, the trannys? no again, the rearends tear them apart, well no, so I said what was the problem the headlights burnt out, the blinker fluid leaked ???? What be specific, when push came to shove it turned out he never had an AC was his neighbors and he heard he had all these problems..............yeah right.
Gary(WI)
Orange Level Joined: 27 Nov 2009 Location: WI Points: 1001 |
Polk Diesel in Madison Can Check viscous damper I do not of a way to check to other style but There used to be a place in California that would re pour the rubber ones Gary
Post Reply | |
