Converting a WD to 12 volt
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: Converting a WD to 12 volt
    Posted: 04 Mar 2018 at 7:08am
Kicking around the idea of converting the WD to 12 volts. I know lots of people have, but what exactly does it all take?
 1. Its a magneto ignition, so that shouldn't require anything at all, correct?
 2. The 6 volt starter is just about kaput. Do you just have it rebuilt with 12 volt windings, or is there more to it?
 3. I have no problem making brackets to mount an alternator. I thought about getting one of those mini ones that are about 35 amp. I know I've read on here about having to rev up the engine to get certain ones excited. I thought a guy could put a smaller pulley on, or turn the existing pulley down smaller to make it spin faster. Always good to have a machinist friend...
 4. In a pinch, is it O.K. to jump start a 6 volt system with a 12 volt battery? I know it works, but can you wreck something? I tried it once, I hooked up the jumper cables, pulled the starter rod, and unhooked them immediately. Boy, I've never heard that tractor spin over that fast. I'm not sure if the impulse was even working! The engine in my pickup sure bogged down when I hooked up the jumper cables, though.
I'd like to keep the tractor original, but it sure would be nice to run LED's, an electric water pump, sprayer, maybe a winch, stuff like that.
Edited by littlemarv - 04 Mar 2018 at 7:16am
The mechanic always wins.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 7:33am
Understand everything seems to run off 12V now. But does your starter not want to turn the engine very well? You have to hit it several times to get it to turn? Take the starter apart and check everything. Does it have scratch marks on the armature like it's been dragging? Replace both end bushings. What do the brushes look like? Wore out completely? Clean real well and look at the windings. Is the varnish coming off? You might try respraying it with a heavy duty varnish. Let it dry real good before you reassemble. May work or may not. You haven't spent very much so far, and if it works you got a down payment on a WD 45. LOL PS I guess you have the heavy cables going to everything?        Leon
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 7:37am
1)  Nothing required as far as changing the ignition circuit is concerned.
2) 12 volts will work on a 6 volt starter, but if the starter is kaput, have it rebuilt.
3) I'm all in favor of using those mini Nippondenso alternators, but I haven't seen a one-wire version of one anywhere.
4) I'm not a fan of jumping a 6 volt system with a 12 volt system.  Spikes and stuff can cause too many problems, not to mention the inrush current to the 6 volt battery. Besides, if you want to use LED lighting, 12 volts is a better choice.
A winch takes a heck of a lot of power. You'd need a bigger alternator. Remember that alternators are rated at peak current. A 35 AMP alternator is only good for about 17 AMPS, continuous.  Good luck finding a 6 volt winch.
Edited by DougS - 04 Mar 2018 at 7:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 7:54am
Very good points. I forgot about the cables. I know the bane of 6 volt systems is voltage drop. When you only have 6 to work with, you need every one. For the ground cable, it has a very long steel braided ground strap. Its about 1" wide. It goes down to a bolt directly under the battery box. I don't think the positive cable is big enough, I will take some pictures today and maybe shoot a video of it starting. I cleaned the carb when I got the tractor, and I had the mag rebuilt recently due to a miss under heavy load, which did solve that problem. It runs great, just doesn't seem to want to get going. When I got the tractor 3 years ago, it started fine, but has been deteriorating over time. Guess its time for some long overdue maintenance, nobodies fault but my own.
I have read on here umpteen times that you need to clean 6 volt connections twice a year. I have never done it in the last three.
No matter what, the starter kicking out thing needs to get resolved. If I get that rebuilt, and put some big honking cables on it, we will see how it starts then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 8:06am
Make sure to check the field coils to see if they are shorting to the case. I have wrapped a piece of black tape to stop that. If you have a starter shop where you live you can take it there to see where anything is shorting out. When putting the starter back in don't over tighten the set screw as you can distort the case and bind things up. In fact it might be a good idea to check it and see if that is what is happening.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 8:20am
As an example, Steiner Tractor has an alternator and bracket kit for the WD.  If you have any lights on your tractor the bulbs need to be switched to 12V or upgrade to LEDs.
If I was going to convert an old tractor to 12V, I'd install a new wiring harness.  Putting all that juice through the old wires may get interesting.  Keep a fire extinguisher handy the first couple of times you run it.  Sounds like a good project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 8:31am
So, can I get the starter rebuilt and then just hook it up to either 6 or 12 volts?
Oh yeah, forgot to mention a couple weeks ago, the steel band came off the back of the starter, revealing a layer of duct tape. That just can't be good.
I've never thought about it. Can you buy a new starter? Just in case my case is shot or something.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 8:42am
I converted my D14 over to 12 volts around 30 years ago and kept the starter as 6 volt.  Really spins over fast but it is hard on the starter itself.  Usually the spring inside it breaks every 5 years or so.
Before you do anything, get your old starter rebuilt and use thick cables.  You may be surprised at the difference it makes.  If you have a crappy starter, 12 volts isn't going to help anything.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 8:44am
Yes your 6V starter will work with 12V.  New and rebuilt starters for the WD are available on ebay but there may be a better source.  Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 8:47am
Steve can rebuild your starter or sell you a rebuilt one. You don't want to crank a 6 volt starter with 12 volts for too long without giving the starter a rest, but the tractor will usually start very quickly.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 9:13am
The only thing I understand about the starter using 12v is don't grind on it very long at a time if it won't start. I guess starter really doesn't care if 6 or 12v. Check out Duey's page    http://dueyschutter.freeservers.com/
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 10:03am
I converted my WD to 12 volts about 15 years ago.
The 6 volt starter works just fine.....I replaced the brushes a couple of years ago but
I consider that maintenance.
The first big snow we got was a few weeks ago when we had a simultaneous "cold snap".
I went out one morning when it was two above and the tractor had not been started in about 2 months. Cranked right over and fired right up.
My conversions may be a little unconventional (I've done three) because I use all Ford stuff.
That's because I've "parted out" 10 or 11 Falcons and Comets over the years and I just have all the parts. I simply follow the Ford wiring diagram even using the infamous "pink wire" as the resistor for the coil.
12 volts gives you lots of options....I even have a brake controller for one of my trailers with electric brakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 10:49am
We offer a complete 12V conversion kit for the WD/WD45 if interested. Visit our website. There's plenty of info on conversions, what to do, what not to do etc. Plenty of pics also to look at. Pics of the wiring systems also.  Be glad to help ya out anytime.  Forgot to mention, if your Starter is about done, I can change it over to 12V's the correct way. Its always better to change the Starter to 12 if your going to convert the system to 12. Appling 12V's to a 6V Starter motor makes the Starter violent. This could lead to broken nose cones, damaged ring gears etc.  HTH
bb-customcircuits.com
Edited by Steve in NJ - 04 Mar 2018 at 10:59am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 11:43am
The starter circuit connections are most critical in a 6 volt system. In my lifetime experience which started with my dad's new 1954 Ford is that 6 volt battery posts and connectors need cleaning twice a year, otherwise the corrosion from the battery fumes will make them work on going to an open circuit. When my dad's first new car was a year or two old, I was assigned that task at age 14.
A battery cable from a wallyworld kiosk will be too thin for a 6 volt system where voltage drop isn't tolerated very well.
I don't know about a WD but it has been reported on this forum in recent years that a B or C with magneto ignition may not start well with 12 volts on the starter because its turning too fast for the impulse mechanism to work, but too slow for good ignition voltage.
Jumping a 6 volt system with a 12 volt battery is asking for an explosion of the 6 volt battery from nearly instant overcharging. Sprayed with battery acid your clothes will disappear on the side facing the battery and your skin won't be pale. The acid burn can be serious.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 12:19pm
When it was absolutely necessary to jump a 6 volt tractor with a 12 volt, I have jumped directly to the starter....a bit of fire when you make the connection but it bypasses all the 6 volt stuff. With battery ignition, your 6 volt battery has to have enuf life to provide fire to the points.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 3:28pm
This only works if you have a solenoid between your battery and your starter stud. The OEM WD starter does not use a solenoid.  The voltage will feed back to the battery with a WD. If you *must* jump a 6 volt system with a 12 volt battery, disconnect the battery first.  Never disconnect the battery if you have an alternator.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 3:58pm
Stick with a 3 wire alternator, it's not that hard to do and the exciter circuit will lower the RPM to get it charging. On my WD I put a charging light on the dash to serve as the exciter amp draw, once I rev the engine a little bit the light goes out and the volt meter jumps up to around 14v and stays there even if I throttle back, charges good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 4:17pm
6 volt starter is not a problem on 12 volts... I have heard the story of the impulse going to fast and not firing on a mag....... I have converted several with mags and NEVER had a problem with starting. Good mag, good plugs, good wires and correct timing and they all startup on 1 revolution of the motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 4:42pm
Kind of glad I started this thread. You guys are reminding me of everything I'm neglecting! Come to think of it, I have never put plugs and wires on it, or set the valves. I guess it's time to perform all the maintenance I have been "too busy" to get done. It starts better in the summer, but now that I have been using it in the winter, problems have been creeping up.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 8:28pm
Sounds like it just needs a little TLC instead of a conversion.  My WD is well maintained and still has original 6 volt system with proper sized battery cables.  It always starts, even in the coldest weather (-20C) and even tho it has an engine heater, I've never plugged it in.  Any colder than -20C and I don't want to be on it!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 8:48pm
When I go up to dads, I'm always in a hurry. Gotta run up there, usually with at least one kid, try and get something done, then scramble back to town for the next sports or family or school event.  And heaven knows, if you are in a hurry, nothing goes right so everything takes longer anyways.  The WD has always been the workhorse.  I've always just jumped on it, did what I could, and left.
Anyways, here's the starter and cables.
And here is a video of how it starts....eventually.
Keep in mind, it usually starts a little better than this, I just crank it and pull the choke rod out, as soon as it pops once, shove the choke back in and off it goes.  But I didn't have enough hands while filming.
So, since it will be mud season before you know it, and warming up a bit, might be the perfect time to rebuild the starter, new cables, plugs and wires, and valve adjustment, before we start field work in the food plot.
What is the recommended size battery cable for 6 volt?
Edited by littlemarv - 04 Mar 2018 at 8:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 9:08pm
 Cept he has a magneto! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 9:41pm
Found some other posts, looks like 00 gauge is the way to go.
I had a 12 volt battery in a forklift explode on me once. You RUN to the nearest water hose, that's for sure. But the most terrifying part for me was the BANG- louder than any gun I've ever shot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 10:14pm
CTucker,
Yep....That's why I qualified it by saying "if you have battery ignition".........
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 11:56pm
Actually turned over quicker than I expected. Much faster than dads CA even with a new battery. His starter stops after a revolution or so of the engine. Two quick pulls of the starter rod and then it usually starts. May need to look into larger battery cables and a starter rebuild also. I dont want to convert his to 12v if I can resolve the issue.
Good post
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 4:10am
#0 AWG if you can find it.  Have your local truck shop build a set from welding cable. It's more flexible.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 5:16am
Basically it boils down to with a 6V system you hope it'll start,with 12V you make it start.
12V is a lot easier on the starter because the engine will almost instantly fire up
once you hit the starter.Also 6V batteries don't hold up well compared to12V I've used.
We struggled with our WD45 for years with a 6V system then finally changed over to
12V should have done it years before we did.Was very nice to go out on a 10 degree morning and hear the motor spin over and fire right up.
When it comes to a tractor I'm using to work with I want what works best not some antique system that was state of the art 50 years ago.You still use the same phone(if you even had one) that you used 50 years ago?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 9:22am
Fundamentally 6 volt systems have worked for more than 3/4 century. They do require more attention to connections, especially at the battery posts.
Today the selection of 6 volt batteries is very limited and they often sit on the shelf a long time. When buying a battery it is beneficial to learn the manufacturer's date coding and to hunt the stock for the most recently made to get good battery life.
The typical three brush generators are only limited in current, not regulated for voltage and depend on the user to back off the charging current after the battery is nearly fully charged, else they will overcharge the battery which shows as a regular (almost daily) need for water replacement. The voltage regulation of the more modern internal regulator alternator can give many years longer battery life. I put a 12 volt engine in my 1964 VW Beatle and built a solid state regulator of my own design and continued with the car being 6 volts and essentially doubled battery life. That is hard to do commercially, but 12 volt internally regulated alternators are very common these days and will give much better battery life and the choice of batteries for 12 volts is huge.
But 12 volts is not original for vintage tractors.
Gerald J.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 9:39am
If originality is very important, stick with 6v, replace the cables, clean all the connection points.  If you want faster cranking, lower battery maintenance, a greater choice of batteries, the ability to jump-start other machines (and have them jump-start you), would like to add great lighting or other electronics, swap the battery to 12v negative ground, put on an alternator, and replace the bulbs in all the lamps.  I've converted all mine, and a dozen of others', for those reasons... with absolutely no complaints of any kind.
One thing that nobody has noted-  the worst thing you can do to a starter motor, cables, solenoid, and battery, is underpower it.  When you stall or drag a starter motor, the windings carry substantially more current, and the stall and drag is irrelevant of reason- poor bearings, worn brushes, or insufficient current and voltage supply from the system.   When you provide ample voltage and current to spin the starter motor, it's draw is lower, because the higher armature speed means faster commutation, and the reactance in commutation is substantially higher.
The starter in my Hercules 338ci JXLD inline six is a 24v DELCO starter.  I'm cranking it with a 12v 4D truck battery, and it rolls it over just as well at 12v as it does it's original 24v... it just draws three times as much current.  When I took it to my local shop for a rebuild, I asked them what it'd take to swap the windings for 12v operation, he looked it up, and said same starter uses all same componentry, and same wiring... no difference between 12v and 24v for that unit... just a different solenoid winding, and a different reading on the meter under load testing.
Now, I took a listen to your WD start, and what's happening, is that when your engine crosses TDC and SLIGHTLY fires, the starter is unable to 'stay with' the ring gear as it speeds up.  By the sound of your starter bendix, I'd say you'd benefit from a starter rebuild.  The kicking out is not only annoying, it's hard on the ring gear and starter bendix.
The ground strap is a bit long, but that's probably not having as much impact as the ground connection path from the cover bolt to the starter housing.  On these, the starter nose is simply slid into the torque tube casting, and a binding bolt clamps down on the starter nose shell.  When you rebuild the starter, cleaning the casting, nose, and that bolt point and threads WILL help.  I don't understand why AC didn't spec a grounding lug on the side of the starter shell, but they didn't.
Your magneto impulser sounds really sharp and loud... perhaps it's just your camera and the inside of he building, but all my magnetos aren't that bright and metallic-sounding...  almost sounds like the impulser's internals are hammering against the housing a bit.
If you really, really, really want a good-starting tractor, hand-crank it... and then get the carbeuration an magneto set up so that it'll hand start easy.  After that, it doesn't matter WHAT condition the battery, cables, and starter are in, it'll still start easy...Tongue
Edited by DaveKamp - 05 Mar 2018 at 9:50am
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 9:59am
