Looking to Buy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Looking to Buy
    Posted: 03 Mar 2018 at 2:22pm
a 2008 GMC Sierra 1500 4x4 Extended Cab.  It's got 160,000 miles on it, 8 cylinder, and it's a Flex Fuel.  It's LOADED!
Anybody have/had one?  What to look for?  Problems?  Price?  ANY help is greatly appreciated.
Thanks Guys.....
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 4:22pm
Did you do the carfax thing on it?  No fun getting a flood victim.  If it's got a timing belt, it's time to put a new one on.  If it's got a chain then that's one less thing to worry about.  If I were in the market a GM would be my second choice.  I would never buy a dodge or a road dumpster Ford.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 10:46pm
I don't buy GM, I buy FORD......... but some common things..
-- starters last about 160K miles.. give or take... might consider new soon
--alternators last about 160K miles... give or take... might consider new soon.
--see when they last changed the spark plugs.. FORD runs about 100K each set
--see when the trans oil was last changed ... maybe axle and transfer case also.
160K miles is just getting broke in for well maintained truck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 7:20am
what you are looking at Ted, is a good choice! that's not many miles this day and age, usually that year truck will have 300,000 miles or better on it by now. flex fuel is o-k, but the E85 won't get you the miles that regular gas will. but it's good when you spend to much at the bar and can still gits home on less $$$.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 9:22am
Had a flex fuel GMC. Won't own another. Parts are expensive. Don't use the same parts as regular gassers.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 11:45am
You are going to be looking at replacing the insterment cluster if it hasn't been done. Buy a rebuilt one or after market 1. Takes a few minutes to change. Fuel pump if it hasn't been changed. Gmc sitting in my drive way has over 500000 miles on it 1 fuel pump and several sets of brakes and tires, 1 rear leaf spring.
VFDfireman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VFDfireman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 3:19pm
Honestly it really comes down to how the po treated it.
If its pretty clean of dents dings etc on the underside items like mufflers and oil pans it’s probably spent much of its life on the highway.
If it creaks, groans, clunks going over parking lot transitions then it probably needs suspension work. At that mileage you should budget for ball joints at a minimum or make the seller do it as part of the sale.
Are the factory shocks still there? If so those were bad 100k ago..
Last time tranny fluid replaced? That mileage on original fill is not good. Same goes for coolant.
1954 WD45 Restored 2015
Current Project: 1953 IH R120 Pickup truck
CB
"It's better to be thought a fool than to open your mouth and remove all doubt."
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 4:21pm
About time hte front wheel bearings are due for the 2nd or 3rd set to be installed - mine went at 58,000 the first time
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 9:38am
Well Ted. Did you buy it? I have a new trailer sitting in my driveway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 11:53am
Nope Mike, I didn't get that one, but I did get one.  I'm gonna start a different thread.  Glad to know I can borrow your trailer......Big smile
