Case backhoe brakes?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Case backhoe brakes?
    Posted: 28 Feb 2018 at 8:51pm
How much trouble to fix the brakes on an older 480-580 Case backhoe?What kind were they. Did they give trouble?  Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 5:27am
All I have ever seen were hydraulic assemblies mounted externally to the transmission housing. A bear to deal with but when get functional are pretty decent. One caution, SOME of these required hydraulic oil NOT brake fluid in the master cylinder system. Need to get a service manual to verify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 5:58am
I thought the buckets WERE the brakes on backhoes ! hehehe
just some fun before Shamless' machine dumps up to 12 inches, YES a FOOT of wet, heavy SNOW on me later today.....
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 6:23am
580B brakes are easy to work on.  They are a band brake that the housing comes off easily with a few bolts on the side of he rear/transmission housing.  There are little springs that hold the band from dragging when released.  Change them while you are there as they are not expensive but when they brake the brake drags.  Last time i replaced brakes on one I got them from broken tractor.  Good brake parts and lot less money than case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 11:27am
It is a 480c if that helps. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 1:07pm
Found this, pretty explanatory:
https://www.youtube.com/watch?v=5bjpMO2bnd8
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 7:53pm
DMiller, thanks, very helpful! Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2018 at 1:05am
brakes? who needs brakes? lol ...thanks Jay!
