Restoring a 1940 Allis Chalmers Model B
PickyPotatoPosse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PickyPotatoPosse Quote  Post ReplyReply Direct Link To This Post Topic: Restoring a 1940 Allis Chalmers Model B
    Posted: 28 Feb 2018 at 12:44pm
Hello everyone! I recently came into ownership of an Allis Chalmers Model B, Serial #17XXX, which should place it around 1940. It has the sickle mower bar. The last time it ran was about 8 years ago, and as I was not the owner, it was not taken care of. It has spent most of its' life out in a shed, out of the elements. I would like advice on how to get started restoring this beautiful tractor!
The current problems, as far as I can tell, are as follow:
-Gearbox sludgy(slow/hard to shift into gears)
-Hard to rotate crank
-Doesn't start(haven't tinkered yet though, I'm sure the carb is pure varnish)
-Finish is terrible because of an extra layer of red lead paint
-Flat rear tire, tube doesn't hold pressure and the sidewall is cracked
I've given it a lot of thought, and I've gotten it down to a few decisions to make right away. Refinishing it can come later:
-Do I make it run, then worry about taking it apart and rebuilding the engine, or just dive right in?
-How far should I rebuild the engine? New sleeves, cylinders, all the way down to the shims?
I've rebuilt a 1982 Honda cb750, and I've worked with modern automotive engines for most of my life, so I at least know how engines work, however I've never tackled anything this old. I have a shed to work in, and it would probably be a good idea to invest in an engine stand.
Any advice or opinions you can offer would be greatly appreciated. Thanks!
Gerald J. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2018 at 1:59pm
CAL(KS) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2018 at 2:04pm
get it running and moving to determine whether it need engine or transmission work.  then evaluate what needs to be done and the costs and decide from there. start with a few squirts of oil in the cylinders to lube them and then work on fuel and spark.
Edited by CAL(KS) - 28 Feb 2018 at 2:05pm
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2018 at 3:06pm
I recently bought a D-15 that the seller said was locked up . The starter and the oil pan were both off . My son and I found the motor was loose , so I bought new ignition parts . Put some gas in it and surprisingly it started . I was advised by someone on here to get it running and see what's what . So I agree with CAL , see if you can get it running .
Post Options Post Options   Thanks (0) Thanks(0)   Quote PickyPotatoPosse Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2018 at 3:10pm
Thanks for the suggestions so far! Somehow that manual managed to evade my searching. I'm reading it now, and I can tell it will be a huge help. I'll pull off the carb this weekend and fix that up, and see if I can get her running in a few weeks.
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2018 at 5:50pm
I concur.  Get it running.  Many times something simple stopped the tractor from working and life gets in the way--it gets forgotten about and sits.  This is the most thrilling part of the chase for me.  Finding one and getting her running.  Restorations are cool, but wrenching is eminently more fun--for me.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
drobCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2018 at 7:51pm
is it hard to crank with the plugs pulled?
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2018 at 7:56pm
x2!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2018 at 8:04pm
Good advice so far. Drain the engine and transmission oils and check for contamination (water, coolant, sludge, etc.) and change the oil filter before proceeding too far. Once you get it running you can find out what else is needed. And welcome to the Forum, you will find some good advice here.
Bill Long View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2018 at 8:49pm
First, Congratulations for obtaining my favorite Allis Chalmers Tractor.  You will find it is a very basic unit.  East to work on with parts readily available.  Castings and assemblies can be obtained from sponsors of this forum and even on e-bay.
I agree with the others to see if you can get it running then decide how deep you want to go.  Frankly, I hope you will go "all the way" and restore my favorite.
I would love to join you.  Let us know how it goes.
Good Luck!
Bill Long
BEK View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 8:32am
You chose a good tractor.  They are incredibly easy to work on and as stated parts are readily available.  Just some quick thoughts on restoring your B:
The upside.  I like to tinker and my kids helped out with the restoration of our B.  Memories and fun times I won't soon forget.  The other reward came when it was all fixed up they each learned how to drive on the B.  Even learning how to operate a manual transmission.
The downside.  These little tractors have a finite value.  Your restoration can easily exceed two to three times the value of the tractor.  This is money you may not get back.
Overall, my B restoration was a great experience.  Good luck with your restoration.
Edited by BEK - 01 Mar 2018 at 8:33am
Post Options Post Options   Thanks (1) Thanks(1)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 9:02am
the "probably won't get your money back argument" is quite valid if you're doing this as an investment, but I think does not apply if like me you never intend to sell it or even trade it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PickyPotatoPosse Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 9:41am
It is not in my plans to get money out of this; I plan on keeping it for the span of its' or my life, which ever ends first(Probably mine, knowing how they built things back then)
Unfortunately it's being kept away from my house, so I haven't pulled the plugs yet or started tinkering. I would have to agree that wrenching on things is more my style, but this is a great opportunity to learn a new skill.
Seeing as this is tractor is 88 years old, I assumed I would have to dive all the way in, replacing shims, bearings, bushings, etc. I guess that's why I am a bit confused as to why everyone says to get it running first, then decide how deep to go. But I won't argue with experience, if that's the route that everyone suggests, then that is the route I will follow.
But if I decide to rebuild the whole engine(which seems like a good idea), does it pay to get it running first? At any rate, I think the easiest thing to start with is slapping a new tube on the rear tire, that will make moving it around a whole lot easier. Now, just have to figure out the tube size...
Thanks for the great advice so far, this Forum is more help than I could have imagined!
Reindeer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 9:52am
You never know what condition the tractor will be in.  Assuming the worst is not a bad place to start, but getting the motor working, checking compression, cooling, oil all tell a story that is hidden from view until you can get them turning over.  I am working on a 67 D15 Allis, and despite years spent sitting outside, the motor is in quite good shape.  Compression on all cylinders was over 140 psi.  The oil was dirty,  there are oil leaks from dried out seals but after cleaning up the carb, and draining the gas tank it runs very well.
Still going to cost more to fix than it  would to buy, but I could be spending my money on recreation, and I find the satisfaction of seeing the old tractor run and work is more than enough compensation.
Edited by Reindeer - 01 Mar 2018 at 9:53am
BEK View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 10:44am
Everybody here is steering you in a good direction.  Get it going and proceed as you see fit.
These old tractors are like a bar fight.  If you go out drinking and looking for trouble, you'll find it.  Tear into your tractor thinking it needs to be fixed and you will find something.  Restored or unrestored, there will always be stuff to fix.
Your tractor is 88 years old.  Like people at 88, it will have quirks and character.  That's what makes'em fun.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 11:05am
If it's a 1940 that would make it 78 years old unless I was taught wrong when I was in school many, many years ago. Wink
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 11:10am
Everything said so far is true! If it won't run it may not be worth the expense to do what you are considering. You will never get your monetary investment back but hey I have always believed education is expensive. You have to love these old tractors or why would you own one? (just my thought)
Post Options Post Options   Thanks (0) Thanks(0)   Quote PickyPotatoPosse Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 11:16am
Wow, where did I get 88 from? 78 years is correct. Ok, I'll take the advice and get her running before delving too deep. Seeing as this is now a hobby, cost isn't the *biggest* constraint. I don't plan on selling it. First things now will be to order a carb gasket kit and rear tire tube. What are your guys opinion on websites for parts? I noticed djstractorparts.com has a good selection.
Gary View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 12:58pm
Starting with cleaning the carb is the right idea.
But before you reinstall it, remove the gas tank and thoroughly flush it out.
A handful of crushed stone shaken all around inside the tank is a cheap scale remover.
Flush thoroughly with water and blow dry.
Don't forget glass fuel bowl and strainer.
Gary
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 3:39pm
I am not you but if I were I would first remove the valve cover and make sure all the valves would move down and come up by them selves. You would need to turn the crank over to check all of them for being free. If any were sticky/slow to come up, I would squirt oil on the stem and work them up and down until they were free.
Sticky valve stems can cause the engine to turn over hard even though they are not stuck/ needed to be forced up by prying under the spring cap. If any are stuck I would check for a bent push rod. Stuck ones can be worked until free as well in most cases.
Unless the pan has been full of water it is unlikely that the rod and main bearings would make it turn real hard unless they were new bearings before not being used. Dry rings can though, so advise in squirting some oil in the spark plug holes is good advise. Some of that magic elixir stuff works well in this case but oil is oil if it is clean and the engine will turn over with a crank.
Those would be my personal first things to do on the engine take it or leave it. I would want it free turning before adding spark and fire.
Then off to carburetors and magnetos and other need checks and repairs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 6:27pm
DJS is good as are the other vendors that advertise on here and support this Forum. I have bought from them as well as OK Tractor and Tony's Tractors and have never been disappointed. For carburetor and magneto work and wiring kits Steve at B&B Custom Circuits can't be beat.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 9:51pm
Listen Closely to what Dick L says.  He is one of the best mechanics I have never met.  His advice is Gospel around here.
By the Way  Welcome to the Forum
Again, take good care of my favorite.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2018 at 11:07pm
All good advice, but the first thing is getting all the old gunky oils and greases out.  Drain everything and it should turn easier.
Then turn it like Dick says and see if the valves work freely.  You also get to look at the valve springs this way to see if any are broken.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PickyPotatoPosse Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2018 at 7:46am
Sounds like a plan! I noticed in one of the manuals I found, it mentions using some pretty thick oil, I think 120 or 140, for the transmission or final drive. After sitting for quite a few years, I have my doubts that it will just drain out, especially in the chilly early spring. Any idea how best to get all the oil out, without tearing it apart and scrubbing?
1940 B in restoration process
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2018 at 8:32am
Take the (plugs) out of the bottom of the transmission and let it run or drip out first. You can tell by what comes out if other methods are needed. Thick oil will still run out slowly. If it has a hydraulic pump it will most likely be thin if it is not empty. I have bought several that was empty and full of rust.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2018 at 5:22pm
The transmission and hydraulics will all run together. 3 drain plugs for  them. I put trans/hydraulic fluid in mine. The finals you have to take the pan off and empty it-no factory drain plug. I have not done that yet!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 2:02pm
Have you got one of those hand pumps for weeds?  The kind you push the handle up and down to put pressure on the inside?  Well, put some diesel fuel in one and stick the end down inside and move it around as it's spraying.  Some more of that gunk SHOULD come out.  You just have to be patient and let it drip. . . . .
Put the plugs back in then DON'T fill anything except the oil in the motor.  AFTER you've got it running, you can put more diesel in the tranny/hyd pump, and run it down about 50 feet, put it in reverse and come back 50 feet.  That should thin any 'gunk' left in there.  Drain that and then try to inspect OR,,,,,,,as I do,,,do it again.  When the diesel comes out, just about as clean as it went in, then drain that good and fill everything to the full points with Universal Hyd/Trans fluid.  You're done with that.
Hope this helps...
Post Options Post Options   Thanks (0) Thanks(0)   Quote PickyPotatoPosse Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2018 at 11:57am
Pulled apart the carb this weekend, I was pleasantly surprised at how clean(relatively) it was.
On another note, I noticed that there isn't a muffler, just this perforated pipe, which is fairly loose to the touch. Was this ever standard, or just a home job like I assume? What is the proper muffler style for a 1940?
The fuel line(rubber) is pretty stiff and cracked, so obviously that will be replaced. But right now it has an inline fuel filter(also needs replacing) but I have a fairly clean sediment bowl sitting on the shelf. Is there a significant advantage to the fuel filter? Assuming I get all loose garbage out of the tank and replace the seal on the cap. I would prefer the sediment bowl, because that was the original style. (Also if anyone has a picture of the original fuel line routing w/ sediment bowl, would be a big help)
ErikR View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ErikR Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2018 at 12:29pm
I prefer to see an original looking steel line and sediment bowl instead of a rubber fuel line that someone looped in front of the air cleaner...
Replacement steel lines are available from several vendors.
FYI, these are not my pics... I found them with a google image search.... Sorry if they belong to someone here.
1950 B
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2018 at 2:39pm
Inline fuel filters tend to have a few PSI pressure drop intended for use with a fuel pump, where on most tractors it sees only a fraction of a PSI pressure from gravity flow and so the inline fuel filter can starve the engine for fuel. There is one or two (out of 100) inline fuel filters made for gravity flow but they are rare and hard to find and may not flow enough fuel for anything bigger than a lawn mower. Go with the original sediment bowl with a screen at its top. Be sure to clean the screen above the sediment bowl filter inside the fuel tank. You might need to replace the fuel line, they can be nearly plugged with varnish. Sometimes they can be cleaned by shoving a steel wire through end to end. And check the screen often on the inside of the carburetor at the inlet elbow adapter. I've seen them so plugged that 60 psi from an air tank didn't flow.
Gerald J.
This page was generated in 2.568 seconds.
