PDF manuals
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Topic: PDF manuals
    Posted: 27 Feb 2018 at 5:15pm
Well Guys, I do admit that I have a piece of machinery besides my allis things. It is yellow not Green. I have a J. D. 450 C track loader and need to find a PDF manual to load down. Have a bad water leak and can not locate it. No radiator leak, no block leak, water pump ok, water out of belly pan. no water in oil either. I wondered if there are any water lines in the belly pan area ? I never knew of any. Any help appreciated.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 6:13pm
Randal - Check at JDCrawlers.com
HTH's
Orangeman
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 7:05pm
Does yours have the oil cooler under the oil filter? There are coolant lines going to those which might be hard to see a leak from. Just a thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 7:43pm
Does yours have the tank type coolant heater? Don't know if you have a hard copy parts manual and you likely already know about the John Deere on line parts catalogs. If by chance you don't try a search for JDParts:Homepage that will get you to where you can get to their online parts catalogs, order manuals, etc., similar to the AGCO site. I've got a 450E dozer but I can see from looking at the cooling system parts there are enough differences in the two machines, my tech manuals won't help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 8:07pm
thanks , I will check the sites.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 8:11pm
Jim, there is an oil cooler attached to the side of the radiator and directly behind the filter assembley. I think I will have to pull the front and belly pan to find leak. thanks. I will let all know the fix later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 9:41pm
Randal, The cooler beside the radiator is normally an air/oil cooler for the transmission. Some of the John Deere engines had a small engine oil/water cooler, it is kind of an add on that fits between the engine oil filter and the filter mounting surface on the block, with tubes and hoses supplying the coolant to it. Good luck with your search.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 10:12pm
thanks everyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2018 at 5:38pm
Jim, I do not have a cooler bolted to block behind the oil filter. will probably be a few days till I can work on it again. rain here, and cooler temps coming. will post later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2018 at 6:04pm
oops, Jim I found the oil cooler at the oil filter. Guess what, the rubber line was leaking at that cooler. Hard find and will be a hard fix also. lines are about 4 inches long each. no room to get at the clamps. I do have a little play in the water pump shaft and will go ahead and change it also. Thanks for mentioning the cooler. lines were hard to see tucked under the side frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 5:34am
Glad you found the leak. That is a great arrangement isn't it. The oil cooler on the 450E series is a tube type cooler separate from and below the oil filter, a bit better to get at the hoses on it. My water pump had some play in it and I rebuilt it in January. When I got it off I looked at all the hoses, nothing leaking but most were pretty hard, so I decided to change all of the hoses while the cooling system was drained and the access was better. Luckily all my clamps have the hex head screws so a 1/4" drive set up got the ones in tight spots better than a screwdriver would have. I also changed the fan belt as well, while I could see the bolts of the pump drive at the dampener pulley to split it for the belt change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 7:55am
I don't know if my clamps are hex or not yet. hope for hex. my fan belt comes off easy. just loosen the alternator. from what I can read the radiator is held by a bolt on each side at top, and sits on a pivot pin in the bottom. Is that correct ? thanks for your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 9:47am
The alternator should be on a pivot bolt at the bottom, between 2 brackets, and have the adjusting bolt in the strap at top. Yes, the fan belt comes off the fan and alternator fairly easily. If you need to change it that might not be as easy as it looks. I believe you will find you have to unhook the hydraulic pump drive from the dampener pulley to change the fan belt.    Search T42183, Hydraulic Pump Drive to see it on the JD parts catalog. 4 each 3/8 bolts in a rectangle hold the drive hub to the dampener pulley. You will see you have a C-clip on the splined end of the drive shaft. You need to remove the one at the engine coupling end to be able to slide the coupling away from the dampener pulley to make a place to get the belt out and back in. It will be a lot easier with the water pump, fan and alternator out of the way. If there is any doubt on the belt I recommend changing it while you are there. Personally if my clamps aren't hex drive in those bad locations, I'd change those when doing the hoses and position them as best I could to get at them if needed, without having to tear other things off, just in case. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 12:33pm
will do Jim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 2:43pm
As far as how the radiator is mounted, I think there is a 1/4" bolt through an isolation mount at the top tying it to a frame across the front of the engine. On the bottom of the radiator, from looking at the 450C parts breakdown, I think it has two isolation mounts with a bolt through each to catch a nut welded inside the "feet" on the bottom of the radiator frame at each side. The wheel tractors used a similar method, i.e. bolts up from the bottom of the front casting, into nuts in the radiator frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2018 at 7:24pm
will check it out . thanks for all your help. Be safe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 11:33pm
well Jim, I finally got around to getting the water pump off. sure is a tough job, and nasty one also. fan belt showing cracks , so I will change it. I need to pressure wash engine before re-assembly. when rain stops I plan on getting old fan belt off. when you rebuilt your pump, did you have press arbor or hydraulic jack press to remove the pulley and bearings, seals etc. ? The information you gave me really helped a lot ! Thanks Randal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 6:29am
I have an old 12 ton hydraulic press, similar to the ones Harbor Freight and others have. I don't know that an arbor press would have done mine, the old bearing/shaft started dry. I got my water pump kits (RE62658, I had a 2030 pump to do at the same time) from a our local JD agricultural dealer for about $60 each. I believe yours will use that same kit, have the dealer confirm that if you decide to go that way. It had a new bearing/shaft, cast impeller, seal assembly, and multiple gaskets as the pump internals fit many different JD water pump bodies. The kit also had the driver to press the seal to the right depth in the housing. The JD manual gives instructions on the steps and some clearances. If you don't have a manual yet you can find a downloadable pdf copy of the 450B manual at archive.org. Many of the things are similar on the 450 B's and C's; like the water pumps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 10:02am
thanks for the info Jim. I do have a service and parts manual now. I have not decided to rebuild or buy one online. still weighing options.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2018 at 10:37am
Rebuild is simple if you have access to a press. If you decide to buy on line pay close attention to the pump you are looking at. Many will be listed as fitting and the body will fit in place, but may not have the right arrangement for the hose connections you need to match yours. Been there, done that, thought I was going to save some time and just have a pump to bolt on when the time came, wrong, hence a rebuild. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2018 at 1:00pm
Picked up rebuild kit at John Deere dealer and will begin rebuild of the pump at shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2018 at 6:45pm
Hey Jim, I end up replacing the belt. took the c clip out but no slide on splined shaft. Had to take bolts out that hold pump on and slide dampener away from pulley to get belt on. worked long time on trying to slide dampener but it would only move 1/8 inch . I think there must have been a slight twist in spline once upon a time that prevented the easy road. normal problems when dealing with nearly 40 year old equipment. should finish up reassemble tomorrow. thanks for your info and help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2018 at 5:28am
Hi Randal, Glad to hear you are making progress on it. As long as the shaft is not bound solid it should be fine. I worked quite a while to get the drive end coupling on mine to slide more than the 1/8" you had. I was expecting a twisted shaft or splines worn enough to bind, luckily mine was rust build up in the splines of the shaft and drive end. I was able to get it slid back then took it off and cleaned them so it would slide, the wear in the splines is acceptable for a while yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2018 at 11:01pm
all put back together and running fine. Needs a real good cleaning. I use wolfs head in blue gallon plastic jug from Walmart. cheap and really cuts the grease. I am in need of two of the hood latches and cannot find anything related to them on e-bay, google, or jdcrawlers.com , which appears to have changed their home page. I can purchase them for 40 bucks each, but that is too high for me. any suggestions ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 5:52am
I need a couple as well. Mack used to use that metal style for hood latches years ago, but I doubt Mack would be cheaper than JD. I haven't gotten to getting any yet but McMaster-Carr has some steel draw latches, don't know if they have any the length needed (T-handle Tight-Hold Draw Latches for less than $10.00 each). My other thought has been to try to see if the newer style rubber type will fit. They might be more forgiving of the vibration.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2018 at 8:39am
I never thought about Mack. I know people who have old Mack trucks that are junked out or have old parts laid back . I will check it out. let you know. thanks Randal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2018 at 10:32pm
I believe I found the exact hood latches that we need at C & C Equipment in Indiana. they are 3 3/4 inch long, spring loaded , black , hook on one end and 90 degree pin on top. I was on e-bay , business and industrial, heavy equipment, dozers and loaders, newly listed, scroll down to John Deere 350 C dozer listed by C & C. I looked at their store items which are pages of item, used search engine and typed in hood latches. they popped up. 10 dollars each with 7 dollars shipping for one plus 1 dollar added for each additional latch. Check it out. Randal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 5:18am
Hi Randal, I'll check them out. Thanks, Jim
This page was generated in 0.183 seconds.
