just another dumb oil question
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: just another dumb oil question
    Posted: 05 Jul 2010 at 9:08pm
I see in my manual that on a 190 gas or diesel the bearing clearences are same. So my question is why, other than oil additives, do they take different weight in oil?  IE 10w 30 in a gasser and 15w 40 in the diesel.
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
mooboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mooboy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 9:16pm
I wonder if the bore & stroke are the same for the gasser and diesel.  If diesel has longer stroke, bearing loads could be larger.  Also, diesel engines tend to have more torque at lower RPM's, and compression ratio is about twice that of a gas engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 9:38pm
Additave packages in the oil differ, a diesel runs at a different temp internaly. The 15/40 is a good all purpose oil for most engines but is not graded for gas use.
 Gas engines in automotive use were using a 10/40 for a few years but it was found the lubricity of it was not good enough for severe service in smaller engines and 10/30 was made standard. Now the 5/30 synthetic is used in many.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 12:09am
There is a whole lot more impact at ignition in the diesel than in the gas engine. Just listen to the rattle. Takes tougher oil to keep the inserts from hitting the crank.
Gerald J.
