Kitchen knife sharpeners,,, |
Page 12> |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Topic: Kitchen knife sharpeners,,,Posted: 21 Feb 2018 at 9:25am |
Hey all you lovers of kitchens,,,,and,,,and,,all you cooks too,,,!!! Since I'm head Chef,,,,,I tend to the kitchen stuff and have always had issues with sharpenin knives,,kitchen as well as huntin knives. I just can't do it for chit,,!!. I been lookin on Ebay for one of them "pull across" type sharpeners as I don't really want one of them electric jobbies. My problem is I can never hold the angle right and wind up getting a good edge,,,,then takin it right off on the next swoop. I used to know this guy at work that could put a sharp on a knife like you would not believe,,!! I never could tho,,,, What do others use,,?? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Posted: 21 Feb 2018 at 9:32am |
The drag thru will ruin a good knife. I have one that has 4 ceramics sticks. You put two of the same grit into holes on a wooden handle. The first set thins the edge, the second set puts on the finish touch. So simple and easy. Crock stick from Cutlery World. HTH Tracy
CaseyCreek
Posted: 21 Feb 2018 at 10:45am |
I use something similar for the same reasons. The Spyderco Sharpmaker. Not cheap, but I use knives a lot on the farm and as such I use the sharpener quite a bit. I also have several stones for when I ding up a blade/axe. Some kitchen knives are only sharpened on one side (Japanese vegetable knife or Nakiri) These get the stone. Other knives (Wusthof and Shun among others) are sharpened at fifteen degrees instead of twenty. If you sharpen at the wrong angle, you will be disappointed unless you are willing to work until the edge is converted. I can't see up close for squat anymore so I bought a USB camera which magnifies the image up to 200X and puts the picture on my computer. This lets me see if I have been sharpening at a bad angle or if I still have some curl on the edge. The pull-through sharpeners are usually really rough on a blade and you will get gouges in the cutting edge. No matter what you use, you can see how you are doing much better if you line the edge you want to sharpen with a magic marker before you begin. If the magic marker wears off where the cutting edge is, you know you are in the right ballpark. (Spyderco Sharpmaker demonstration) http://www.youtube.com/watch?v=s2DDpB8Pjho Edited by CaseyCreek - 21 Feb 2018 at 10:46am |
D17 Series III,D17 Series IV, 185
shameless dude
Posted: 21 Feb 2018 at 12:05pm |
I've seen quite a few sharpeners at wally world back in the fishing section, never bought any yet to give a recommendation.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25262 |
Posted: 21 Feb 2018 at 12:52pm |
The one you get from Cutco is OK...though only good for 'regular' edges NOT scalloped ones. I sharpen my 50 yr old Rapala fishing knife , still good today..
I do wet the wheel and the blades ...10-20 strokes per side, I'm done. |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 21 Feb 2018 at 1:00pm |
I am of the nature that "a knife is usually much duller when I get done sharpening it, than it was before I started." That's why for a pocket knife, I use the ones that take a utility knife blade. When the blade gets dull, I change it. I don't hunt or fish, so I don't need a knife for that. Darrel
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 21 Feb 2018 at 2:05pm |
Here's the one I use Joe. But back when I bought it, it was only around $125. I've replaced about 4 of the stones through the years. It take a knack though, you gotta learn. And remember, you're NEVER too old to learn.
https://www.webstaurantstore.com/victorinox-40997-11-1-2-norton-multi-oilstone-honing-system/35340997.html?utm_source=Google&utm_medium=cpc&utm_campaign=GoogleShopping&gclid=Cj0KCQiAzrTUBRCnARIsAL0mqcyo6cJsxAtIrml67S_qw_mxZYoYufblW-LBaYmxryjkG6pex-L9jzoaAnEtEALw_wcB |
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 21 Feb 2018 at 2:06pm |
I'm like Darrel and use a box cutter in the shop. I keep a fold up mini cutter at work and one in the kitchen at home. When they get dull just change the blade.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34629 |
Posted: 21 Feb 2018 at 2:19pm |
I use my knife for many things, and gets dull fast... Punching holes in tin, scraping rust off things, scraping rust out of threads, sometimes using as a mini pry bar, or tryingto turn some screw etc. besides cutting bale strings.
So I just use the angle grinder when I walk past... not pretty but it works...and sharp enough to just press light on the bale strings and they blow apart without any need to saw on them. |
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 21 Feb 2018 at 2:24pm |
I use a drag thru with ceramic rods for the general use kitchen knives. For my good knives I use diamond stones in several grits, usually finish off with a 600. I like Tracy's use of the ceramic sticks, may have to try some of those.
SteveMaskey(MO)
Joined: 11 Sep 2009 Location: Wellsville, MO Points: 634 |
Posted: 21 Feb 2018 at 2:27pm |
I never could sharpen a knife good so I give them to BIL to sharpen. When he is done they are sharp
Ron Eggen
Joined: 15 Sep 2009 Location: Lohman, Missour Points: 557 |
Posted: 21 Feb 2018 at 3:06pm |
Go to your local Amish/Mennonite store, or lots of local flea markets and you will find Rada knife products made in the USA. They offer a great little knife sharpener with two high carbon hardened stainless steel sharpening wheels, and only cost between 5 & 10 dollars each. I have several and use them all the time. 100 % lifetime money back guarantee.
Dave H (NE)
Joined: 11 Sep 2009 Location: Western NE Points: 288 |
Posted: 21 Feb 2018 at 3:40pm |
Wife got me a WORK SHARP Knife & Tool sharpener. cost about 90 bucks works great and is fast. www.worksharptools.com
shameless dude
Posted: 21 Feb 2018 at 6:44pm |
I too like Darrel and Stan, use a razor blade cutter everywhere.
JC-WI
Posted: 21 Feb 2018 at 7:00pm |
anyone use the snap off blades? when the point or blade gets dull, just break it off and got new cutting edge.
HD6GTOM
Posted: 21 Feb 2018 at 7:23pm |
I was lucky several years ago one of my regular customers at the tire shop bought up a pickup load of knives from a slaughter house. They considered them worn out. They are sharp, we have never needed to sharpen them. Probably had them close to 15 years. Old gal uses them daily. Only mistake I made was not buying more of them for the rest of the family.
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Posted: 21 Feb 2018 at 9:06pm |
i use what Dave H (NE) does. Gets me by
shameless dude
Posted: 21 Feb 2018 at 9:12pm |
JC....no....cuz when yer cutting something thick, and you put pressure on them, they snap off, sometimes your knuckles hit where the snapped off blade is.
john(MI)
Posted: 22 Feb 2018 at 12:57pm |
Take one of those large size paint stirring sticks. I think they are for 5 gal buckets. Glue a piece of leather to it. Why do you think old fashioned barbers used a strop? I was told that if you got a good knife it should never touch metal.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4874 |
Posted: 22 Feb 2018 at 2:57pm |
Knife is easy, a lot faster with a diamond stone than the natural ones.
Now drill bits are what I got trouble getting right free hand. I wore out a drill doctor outfit. Got a new one that dose bigger bits when Sears was closing out locally. Been waiting for a rainy day,guess I will just have to get at it.
shameless dude
Posted: 22 Feb 2018 at 3:00pm |
I also have the same problem as Ray.
desertjoe
Posted: 22 Feb 2018 at 5:00pm |
When I quit workin at the local Chevy Dealer, One of the mechanics gave me an unused Drill Dr,,he never could learn to use it so he gave it to me,,,I worked and worked on it but I could not get some good sharps on any drill bits,,then my wife gave me one of those for Christmas,,so to keep the peace, I just put it up in the garage,,NIB,,,, Then I joined a machinist forum and I learned how to freehand sharpening drill bits from a tutorial he wrote up,,,and,,,,and,, I'll bet a case of Black Label,,,I can put a sharp on a drill bit better than any store bought Drill Dr,,and that is the troot,,,!! It was really quite easy and did not take that long to learn his method. If anybody is interested, I will contact him and copy & Paste his write-up so ya'll can read it and try it
darrel in ND
Posted: 22 Feb 2018 at 5:07pm |
Now sharpening drill bits, I am pretty handy at that. Don't know if I am as good at it as Joe is, but I can make em chew through metal pretty good. Learned it mostly own; partly from a friend of mine. This friend of mine couldn't sharpen one to save his ass, but could explain to me how it was supposed to be done. I took the information and ran with it. I can pretty much take any cheap drill bit and make it dig. darrel
desertjoe
Posted: 22 Feb 2018 at 8:39pm |
""I can pretty much take any cheap drill bit and make it dig. darrel "" Ten four,,Darrel,,,that right there is the secret to getin em sharp,,I always try em on my palm by gently turnin em and see if they "dig" into skin with just light pressure. You can also tell when one of the flutes is digging more than the other,,, I do cheat some as I have a drill angle gauge that I use to check the true angle for the bigger thicker jobs,,,
shameless dude
Posted: 22 Feb 2018 at 9:00pm |
I have a bucket of dull bits....
shameless dude
Posted: 22 Feb 2018 at 9:01pm |
now when I buy new bits I buy cobalt ones
desertjoe
Posted: 23 Feb 2018 at 5:38am |
UMMmmm,,,don't you dare throw them away,,,!! You wanna trade bucket of wore out drill bits for bucket of ,,,,,,,,beer,,???
darrel in ND
Posted: 23 Feb 2018 at 6:16am |
I have tried every type of bit out there, but my "self sharpened" ones will cut the best. The cobalt ones break if you look at em cross eyed. Like Joe says, don't throw away your bucket of dull bits. Darrel |
Armand(AZ)
Posted: 23 Feb 2018 at 7:31am |
One of the guys in our woodshop in ShowLow brought in his WorkSharp like Dave has and we went into the custom knife shaping business for the ladies in the park. I was impressed with it.
I bought a NIB Drill Doctor at a garage sale, I must be dense, but I can not make that thing sharpen a bit!!!
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 23 Feb 2018 at 8:11am |
Norton builds an excellent stone in various grits. So you can get a rough edge and then to the finer grit and it'll be sharp. If you prefer a diamond stone, I can't think of the name right now, but there's a company in either North or South Dakota that make diamond stones that are absolutely the best. Get their finest grit stone in pocket size and just slide your knife across it real light. Try to keep the same angle both ways and go slow. This will help you develop repeatable angles. If you get a wire edge on you knife it's not bad, just tip your knife up a hair and do one side at a time. It will come right off, again light pressure. It will be scary sharp. If you happen to have a extra hard knife don't be afraid to use a course stone on it to get your edge. Then finish with a fine stone. Hope this helps. Gotta get to the doctor. Leon
Page 12> |
