301 valve springs
goomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Topic: 301 valve springs
    Posted: 19 Feb 2018 at 10:10pm
Wondering if there is something better than stock valve springs for 301 3000rpm A-pump s200 turbo?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2018 at 7:23am
I've never seen a need for anything more under those numbers. Never seen valve float at 3500 RPM with stock springs either.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2018 at 7:40am
The problem we've run in to, is boost pressure will try to open the valves between cycles. For that reason, we've set up to use BBC springs, for a solid lifter cam, and even roller cam springs to try to keep things sealed up. The place I get them from is not far from you Brian, Competition Products.
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2018 at 6:48pm
 I will be using these springs. They fit perfectly with no alterations and have a closed spring pressure of 100 lbs.
Edited by Beirnesy - 20 Apr 2019 at 9:49pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 7:32am
I use the BBC retainer, locks, and rotator eliminators to sit on the head to cover the counterbore.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 4:38pm
My machinist used his BBC spring pocket cutter on my 426 head. Worked perfect. Using comp cams 26120 springs with corresponding retainers and locks. Installed spring pressure is 80 lbs.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 10:23pm
I have heavy duty springs left off my twin charger set up ! $50 buys plus shipping , good set didn't float at 100 boost and 4800 rpm! Maybe overkill ! Lol
Ryan59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan59 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2019 at 6:33pm
Oh my gosh. Don’t You know stock springs were used for decades and engineers hammered out the correct springs with tree limbs. Think of the wear!!!! 85 pounds of installed height will push the cam through the oil pan. Figure 8x80 equals 640lbs of lard setting on that camshaft. Why I was told on here that the big boys take ink pens apart and use the tiny spring in them for valve springs. These guys scared the life out of me just for thinking about 65lb seat pressure springs. Imagine if I had wrote big block springs.....
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 12:44pm
That’s pretty interesting. You have any pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2019 at 7:50am
What ever you do don't use stock retainers and keepers.      MACK
This page was generated in 0.273 seconds.
