B with truck tires !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: B with truck tires !
    Posted: 18 Feb 2018 at 6:59am
NOT mine,just locally for sale, yeesh TRUCK TIRES !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 7:01am
Tires are fine for lawn mowing but won't pull a plow or disc very good.
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 7:13am
Is that still a 24 inch tire?
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 7:13am
yeah, the ad said 'just add a mower.....' but at $2500 Canucks to me, that's a pricey B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 7:53am
Whew!  I agree.  I can't even sell a restored B for that here in Florida.
1940 B "Lucy"
1972 314H
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 8:30am
Just add tire chains for field work. I plowed and fit ground with turf tires and tire chains. Lots of weight added.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 8:56am
I'd like to find tires that size for my lawn tractor, a CA.  i didn't know they made 24" truck tires.
SNAP IT UP JAY!!  You need another project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 9:12am
I read the ad agin.. tires are regular semi ones ,24.5 inches so rim would be 1/4" smaller all around..wonder if tubes are needed ? And HOW is it really supported ??
oh well I don't 'need' another project...except for a 53' CA....that's be nice..
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 9:16am
here's the link
https://www.kijiji.ca/v-farming-equipment/london/allis-chalmers-b/1333830002?enableSearchNavigationFlag=true
I'm now thinking truck tire is on truck rim  THEN clamped to B center ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 9:19am
rims are cheap
just torch the center section out and leave 4 TABS to mount to the B hub.
Edited by steve(ill) - 18 Feb 2018 at 9:20am
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 11:43am
24.5 tires would be tubeless. Wheels without centers are available that are for the spoked center hubs.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 11:58am
Yeah, it might be odd... but hey... if you're using it for a pavement-based tug, it's not bad.
now, rotate the axles to lower it, nix the reduction drives, shave the treads, then do same from some space-saver spares up front... put on some swoopy Orchard fenders, big chrome headlamps, and move the exhaust to out the side, it'll look like a Duesenberg... supercharge it and flip the transmission gears, take it to Bonneville...
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 12:05pm
Truck tires do come in the 24" tube type, not 24.5 tubeless. They are somewhat obsolete nowadays, however in years past many heavy haulers always used them. You could buy 24" turf tires cheaper unless they were giveaways
Edited by PaulB - 18 Feb 2018 at 12:08pm
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 5:36pm
They do make 24" truck tires. I have some. They would be a pain in the ass to mount on a non break down rim
ICTRCTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICTRCTR Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 9:35pm
Do not put 24.5 tires and truck rims on the Allis center cast wheel .you will be asking for a problem. 24.5 on 24'' rim,the will not stay tight.seen this done lucky the wheel did not come off.Do not put 24.5 tires on a 24'' rim.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 9:50pm
Look at the add top right picture clearly shows tabs welded to the truck rims to bolt on hubs be real cool to use super single radials and run lower air be a nice soft ride
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2018 at 9:20am
They do make 24.5 tubeless tires. I have a truck with that size tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2018 at 9:24am
From the photos they used a 24.5 Tubeless Dayton wheel set OVER the B hub and pulled up with home made wedges.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2018 at 12:04pm
I bought a B years ago with 22.5 truck tires on it. They just welded tabs to the rims and bolted them fast.
Years ago my neighbor bought a JD LA with rotted tires so we took my truck wheels and an assortment of bolts and put them on the LA to bring it home. I still have the wheels on a non running B.
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2018 at 9:44pm
I guess it work with truck rims.  Don't think it's safe to try 24.5's on a 24" rim, first time you pull against it would probably spin the tire and tube.  I've bought old reacap 22.5's that are too old for over the road use but work fine on farm trucks for $40 - $50 each at auctions.  They also have 24.5's and used truck wheels are scrap price or free if they have a worn out tire on them.  The tractor just doesn't look right with those tires.
Allis Express participant
