7060 split update
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: 7060 split update
    Posted: 17 Feb 2018 at 3:55pm
Hopefully found the problem, 2 of the wave springs were collapsed and the oil was deffinitly a higher viscosity than the 821 when we tore it apart, that didn't help matters. Going to put a seal kit and spring kit in and see what happens. Also found the torque limiter was missing a spring and sloppy, so Rick Corder is rebuilding that. Spent the day cleaning parts and changing the oil and filters in the differential. There was some interest in the jacks on my last post so here is a couple of pics of the jacks and other progress.
Thanks
Leon B MO
cob_crusher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cob_crusher Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2018 at 5:09pm
thanks for pictures. where did you get nuts for threaded bolts ? thanks
ac 200 7080 653 da d90.06 6265 f400 ol 77 1650 jd 4230. the reward of suffering is experience. ignorance is bliss. no muff too tuff. i am only responsible for everything. free whiskey naked women.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2018 at 5:46am
I honestly don't remember, it's been to long ago.
Leon B
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2018 at 9:19am
Excellent pictures, thank you for posting sir.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2018 at 10:26am
Any bolt supply place that deals with refineries will have what you need as far as the studs and nuts. Now if you happen to have a buddy that works in a refinery.....
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
This page was generated in 0.095 seconds.
