Opinions on this WD-45's cranking
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Topic: Opinions on this WD-45's cranking
    Posted: 16 Feb 2018 at 2:39pm
This ole girl belongs to a friends of mines Dad, back in the summer it was over-heating
and not running well. They flushed the cooling system, cleaned radiator, replaced thermostat and water pump. They just have had time to go down to the deer camp it stays at and this is how it's running and blowing white smoke at startup. I'm not real up on these but I was leaning towards a leaking head gasket but I'm told there are no bubbles in radiator and no oil/water transfer -  so crack in sleeve or sleeve o-ring??. It's farther than I really want to travel to look at, so what do y'all think?
[TUBE]EGBtSEzq2LE[/TUBE]
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2018 at 3:07pm
Might be a head gasket but for me it would have to get worse that that to motivate me to fix it.  It sounds good to me and no white smoke after starting.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2018 at 3:20pm
Wihte smoke can be unburned fuel ,black to much fuel  blue smoke oil.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2018 at 4:02pm
Let it sit over night next day hold a rag under the drain plug look for coolant then hold a clean white rag over the ex start her up fun it for three min. stop it and look at what's in the rag. if coolant is in the rag then check the comp.
