Allis B engine weights?
39allisB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 39allisB Quote  Post ReplyReply Direct Link To This Post Topic: Allis B engine weights?
    Posted: 08 Feb 2018 at 7:50pm
anyone have an idea where to get engine weights, i am using a 39 B with 3 point, and using it weekly to do a mini farm. thanks.
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 8:03pm
I have a set in NC but that's a long ride 200.00
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
Post Options Post Options   Thanks (0) Thanks(0)   Quote 39allisB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 8:08pm
how much do think they weigh - i could pay the ship
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2018 at 8:48pm
According to an old post 90 lb each Does your front plate have the holes for weights?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 39allisB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 7:47am
no it doesn't have hole for post but i would think simple drill n bolt w spacer would work, maybe.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 8:32am
Y'all need to meet at the GOTO IN GRAY TN. Trade and see the show! Just drumming up visitors. Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 5:53pm
this is a 175 pound old wheel weight cut in half....... had it laying around the farm several years ago........... half on each side.
Edited by steve(ill) - 09 Feb 2018 at 5:54pm
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2018 at 6:46pm
Now that's cool!
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 5:47am
OK, I have a silly question...
Would adding wheel weights to the FRONT rims be 'better' than side weights?
curious as I have a set collecting dust....
Jay
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 7:11am
I like the wheel weights better better because the weight is directly to the ground. The side weights add weight to the axle pivots and bearing causing increased wear. Probably doesn't make too much difference. Use whatever you have or can get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 7:32am
Dave is right..... adding frame weights is like putting a loader on a tractor. Puts more weight on the spindles and bearings.. also causes more wear to the steering parts... Wheel weights are always a better plan, but access to them is much more limited. Some of my small tractors only get 50- 100 hours a year so I don't think its a big deal. If I was running 500 hours a year, I might  look for wheel weights.
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 9:22am
I built a concrete mold to cast reproduction front wheel weights out of lead.
B side weights would be easy
local tire shop will give me all the weights I wasn't, or you can get them from salvage yard
if you painted them nobody would know the difference
lead weighs 50% more than cast iron
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2018 at 12:05pm
I have a similar single wheel weight with no mate to the one above. It would take a long time to cut that thing in half with a hack saw lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 39allisB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2018 at 5:20pm
I am going to pick up side motor weights - i have wheel weights now - about 50 lbs each w bolts. / side motor 90 each, so 180+100 up front, reason is disc on 3 pt is back a ways (the after market 3 pt works Great! but arms are longer dt bolted to tow bar) and makes tractor light when lifted and moving. advantage to longer arms on 3pt is no hitting rear tire w disc on tight turn. - i have original 1 bottom plow and cultivator (they are mid mount and Smart) but take way too long vs 3pt implements for grab n go week end small farm. / i use king kutter implements and work well no issue at all. - i am about to use a new 5 foot box blade at 450 lbs and that's the going bring front wheels up point w wheel weights. 400 ok that extra 50 is loss of steering and holy if on a slight hill. / my logical guess is 180 on motor sides will fix issue as long as no fast idle clutch slip... had that happen - needed new undershorts. fyi I LOVE my B and ability to see the ground, i crank start it. Its a total rebuilt everything and the other week 5 deg weather - one - 4 inch crank to start! 1939 she is..
This page was generated in 0.131 seconds.
