lerio 226 rod beside allis 226 rod
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: lerio 226 rod beside allis 226 rod
    Posted: 04 Jul 2010 at 9:05pm
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 10:10pm
I have a really nice running 226 lerio engine that I would like to install in a WD-45 will I notice any difference in torgue/hp or RPM'S compared to the regular 226. Definitely a larger and much beefier rod.
Jim
LloydCentWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LloydCentWi Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 9:56am
is the bore and stroke the same? I heard the heads are different. With the Leroi having the cumbustion chamber in the head instead of the piston like the Allis. Have no firsthand knowledge of that however. I do have a leroi engine myself, but I think it's a 201. Manifolds are different, different magneto, water manifold on top of engine different and block has 2 bolt cover on side for adding a mechanical fuel pump.< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 4:17pm
the lerio 226 has the same bore stroke and rod journal size. they are two different lerios the 226 with the long rod and canted cap  has a combustion chamber in the head . the other is just like a allis with exception of the crank having a small counter weight thats been drilled for balancing.
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 8:33pm
Is there a way to tell externally without dissassembling whether a Leroi is a 201 or 226 cubic inch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 8:55pm
So are the LeRoi 226's with the combustion chamber in the head any better performance wise than the ordinary Allis style? Could have bought a complete running 226 LeRoi power unit for $150. The guy selling it claimed it had the chamber in the head. I didn't know there was such an animal and figured he was trying to blow smoke up my backside...
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 8:34am
I would purchase it for that and take a chance wither it has a combustion chamber head or not. I personally dont like the head but i like the other pieces that are in the motor that has  the combustion chamber head.
