Seized CA
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Topic: Seized CA
    Posted: 04 Jul 2010 at 9:04pm
Shut down my CA today after about two hours of mowing hay. It sat for about a half hour and when I tried to restart it was seized. Had plenty of oil pressure and water temp was fine. Any ideas on what to look for first would be appreciated. It didn't knock or do anything out of the ordinary.
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:07pm
Any chance your starter just jammed against the ring gear?
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:11pm
Best thing to do is to describe why you believe it's seized. Were you observing oil pressure and water temp before you shut it off? mnoonan has a good suggestion, and it's easy to check. Just loosen the bolt that locks your starter in place and wiggle the starter, then retighten and try again. Good luck, and please let us know how you make out.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:19pm
I've got no idea why it locked up. Like I said it didn't make any noise or anything. It was so hot today I kept a close eye on temp so I'm sure that wasn't it I'm also sure oil and pressure was up. I tried using that crank to start it also and it didn't budge. I can look at starter but don't think thats the problem, be nice if it was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:26pm
If you didn't do anything to the tractor after shutting it down, I would bet the starter gear jammed in the ring gear when you tried to start it. I had a similar problem once after remove a home made hitch I had on the side of the tractor. I had to have a longer bolt to mount the hitch and when I removed the hitch I put the bolt back in the hole. It just happened to snug up the same time it bottomed against the ring gear. Took me a little while to figure that one out and I never admitted it to anybody for some time after. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 9:35pm
Ah, Charlie.....who'd believe you'd do such a thing???!!?? Hope it is a locked-up starter, Walker.
WC, CA, D14, WD45
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 12:49am
If the starter is not the problem I wonder if the head gasket wouldnt have leaked and filled a cylinder up with antifreeze?  Pull the plugs out and see if it spins over, if one shoots out water you know the answer.  I highly doubt this as I have never heard of it before in one of these engines, but there is a first time for anything.
Jim
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 4:29am
I had that problem with a WC, it ran fine, then if you shut it off, it would lock up......about 30 mins later you could start up and run it all over again. The problem turned out to be........sand and sediment from stream/pond? water over many years had formed a layer around the bottom of the sleeves causing them to overheat 9and eventually crack around the base of the sleeve). On shut off, the pictons would seize at the bottom of the stroke until the moteo had cooled enough......ended up having to wash out att the crud and replace 2 sleeves..........motor runs good as new now.......
I need smaller fingers !!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 7:18am
Dave, your story proves that there is ALWAYS something new under the sun!
WC, CA, D14, WD45
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 10:55am
If it's electric start, then It's probably the starter locked in the ring gear. If so then you would not be able to turn it with the hand crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 11:09am
While it has never happened to me, I've heard many times about the starter jamming 2 teeth on top of each other causing the engine to appear seized.
Kev Card View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev Card Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 11:47am
My starter on my WC is quite inclined to lock in the ring gear especially if the batter is discharged a bit it always happened at the most inconvenient times Kev
RC,WC,2 C'S,WD45,185 ,618 LT
If it's orange and rusty Mary don't trust me
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 10:10pm
my C A starter locks quite often some times you cant losen the starter whitout aprybar and hammer try puting it in 3rd gear  get ahold of a rear tire and try rocking it you can tell when it unlocks the fan will move works for me.
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 10:23pm
Have any Dynamite handy...that will fix anything! haha
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 7:34am
I would never hammer and pry on an engine with the starter pinion jammed in the ring gear. You will only cause more problems or at least add to the original problem. Loosening the starter setscrew and removing the starter would be my first choice. If the problem is recurrent, you need to find the cause, most likely a bad spot in the ring gear and or a worn or damaged bendix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 6:34pm
Tucter    did you ever try  takeng a jamed  starter out of c-a or a B cant be done with your fingers thats ware the prybar & hamer come in you dont pound just tap on the starter plus a few kind words helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 7:07pm
Kent, I'm glad you cleared that up. I had an image in my mind of a 16 pound mall and a 6 foot frost bar in the hands of a guy laying on his back prying and pounding on the flywheel. LOL
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2010 at 7:55am
One more thing to suggest, did you shut off the gas when you turned off the tractor?  Hard to believe, but I have had my D14 (with a brand new carb) leak gas past the carb, up the intake, and into a cylinder before.  When I went to start it after a few hours, it wouldnt turn over.  Eventually, the gas leaked past the rings, and after an oil change and a vow to always turn off the gas, its been just fine.  Worth a shot to pull the plugs and see if that makes any difference as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2010 at 8:23am
My D14 starter locked up ocassionally.  With the switch off, I'd put the tractor in 4th gear and rock it by hand until I'd see the fan turn a bit.  Worked every time.  Found out the starter retaining bolt had worn a bit.  Reground the point on the bolt, and retightened.  No more trouble.
I had the same trouble as Dave Everett with my RC. Didn't figure that one out until the sleeves cracked.
