Semi trailer roof repair
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Semi trailer roof repair
    Posted: 03 Feb 2018 at 6:45pm
I have a couple of the translucent top trailers that have a few leaks. What is best method of patching or stopping leaks. Thanks Tracy
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 7:51pm
We had some leaks in the top of our enclosed trailer (just 6*12, not semi, but I assume it would be the same) we talked to a guy at a trailer place where they built trailers, and he sold us some special stuff for doing roof seams, it doesn't ever get completely hard (supposedly). I can take a picture of the tube and post it if you would like. It was expensive though, like $40/tube, and we needed three tubes for the top of our trailer (to do all the seams, since we were at it.....)
- Ben
'39 Model B
Tractors are cheaper than girls, remember that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 8:31pm
Ben, it would be appreciated. Thanks Tracy
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 8:55pm
Not sure how it would work on that type of material but mobile home roof stuff might fix it.  I used to find the leaks and just do them and it worked every time.  That was a long time ago, but they said it had fiberglass in it.  Seems it was $40 for a 5 gal. bucket back then. Early 80's.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 10:22pm
I think them kind roofs are fibreglass,, so might try a fiberglass repair stuff....
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 1:37am
that new stuff advertised on TV is sum really good stuff. "flex seal" I think they call it. I've used the spray on stuff and it worked great and still holding, that was a couple years ago. and now they have a patch like stuff that goes on wet or dry surfaces. you can also gits rubber cement in tubes or buckets.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 7:43am
The toughest stuff I've used is what you get when you put metal roofs on your house. I've never seen it's equal.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 9:39am
The guys at the camper place told me to use white flex seal on the top of this ferd. I actually found a gallon at Menards last week. Was 89.++. First time I saw the white at Menards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 1:36pm
Tracy...couldn't get a good picture as the tube was all taped up and stuff, but I got a good enough look to get the brand and goop type off it, it is Trem Pro 638 SSL, this stuff: http://www.tremcosealants.com/products/trempro-638-ssl.aspx
Seemed to work good, no hard feelings if you want to use something else though. Wink
'39 Model B
rvroofmagic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rvroofmagic Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 1:31am
I recommend using RV Roof Magic as it is specially formulated for Trailers and Mobile homes. One of the unique characteristics of RV Roof Magic is that it has been specially formulated to be compatible with 95% of roof surfaces without needing a primer. For material estimates kindly visit https://www.rvroofmagic.com/calculator.php.
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 7:06pm
Tar ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2020 at 8:04pm
SPAM, reported
Edited by Ted J - 11 Mar 2020 at 8:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rvroofmagic Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 4:33am
A roof coating or sealant on the RV roof will protect it from all types of weather, including snow, rain and other weather extreme. When it comes to selecting roof coatings for your RV, the market is huge. There’s only one market leader that you should be using. It’s called RV Roof Magic, and it’s the closest thing to perfection you’re ever going to get. There are plenty of unique chemical qualities to RV Roof Magic that makes it an ideal roof sealant.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 5:07am
I have used this tape on a box truck roof seam.  I believe it would work on holes as well, even if you had to pop rivet an aluminum patch over the hole first.  I think it would work on fiberglass.  Surface needs to be clean and dry, and when it makes contact it is there, no lifting and resetting.  They recommend peeling the backing on an end to start then work along it pulling the backing as you go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 5:17am
Whatever you decide to put on, BEFORE you do, CLEAN the roof really,really, REALLY good !!!  Also let it DRY really,really, REALLY good !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 6:33am
At some point the fiberglass panels will degrade where nothing will seal them.  At that point will need to cut them out and cover the holes with either more of the same or sheet aluminum.  Chased this issue years back on aging semi trailers and not ever managed a seal that lasted more than a few months.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 6:52am
yeah the Sun ( that orange ball in sky...) sends a LOT of UV to us ! Anything exposed to it WILL degrade over time including natural white nylon tyraps...sigh....
I'm wondering if 'clearcoat'  has a lot of UV inihibiters ? If so, a few light coats might be a worthwhile investment .
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 10:04am
Ted
Check RV Roof Magics profile !
Looks like 'she' exists.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2020 at 7:18pm
Leon R Has it right I think. When we put metal on our roof we use the sealer they recommended. dang it got TOUGH and hasn't let loose yet.      Leon
