Torque of AC 10000engine
walnut1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote walnut1 Quote  Post ReplyReply Direct Link To This Post Topic: Torque of AC 10000engine
    Posted: 03 Feb 2018 at 7:41am
Does anyone know the torque rating of the 10000 engine in a HD11s crawler? I can only find the 99hp at 1800rpm listed.
Ferdinand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 9:13am
by mathematical calculation that would be 288 ft-lbs.
Because narrow is the gate, and narrow is the way, which leads unto life, and few there be that find it.
Mathew 7:14
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 3:24pm
specs from a 1970 ag book I have for a HD11E; which probably had 11000 engine though.
123 hp @1800rpm
95 DBHP
max torque  390ft/lb @1350rpm.
specs for a HD6B were
75 hp @1800rpm
237 ft/lb @1200 rpm
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote walnut1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 9:10pm
Thank you for the information.
Ian Beale View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 1:54am
Merv
My 1970 Power Farming Annual (Oz) quibbles a bit at 122.5 (net) hp for an 11 E and the same torque
Has HD 11EP hp as 140 (net) at 2050 rpm and torque also as 390 lb-ft at 1350 rpm
Max drawbar pull  11E  29700 lb, 11 EP 60,000 lb
Edited by Ian Beale - 04 Feb 2018 at 1:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote walnut1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 9:49am
I’m thinking of repowering one of my 11s’ with a new Cummins using the California CARB program. The B4.5 has perfect numbers but runs 2200 rpms. The B6.7, which was the one they recommended, has too much power even at the 1900 rpm spec. My cousin did an hd9 back awhile with a 5.9, but they aren’t tier qualified anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 10:31pm
Ian; my info also came from Power farming 1970 manual.  lol.  I just rounded figures up.
Still remeber buying that book when i was ten Wink
This page was generated in 0.139 seconds.
