Need a sprocket to fit a tapered shaft
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Topic: Need a sprocket to fit a tapered shaft
    Posted: 02 Feb 2018 at 7:13pm
I would think I could find what I want it I knew how to phrase what I was looking for...
I am needing to repair a drive sprocket on a home-made feed cart. It was originally a flat chain drive sprocket that was on a keyed shaft that tapered from 3/4 up to 7/8. It drove a sprocket on a shaft that was tapered from 1/2 to 3/4. My grandpa had made it with parts from a deere 12a combine. The sprockets were cast and broke. I would like to convert it to roller chain while I am rebuilding it, but I can't find any sort of hub to fit a tapered shaft. Anyone know where to look? I realize I could have one machined if it came down to it, but was hoping for a ready made part. If anyone has any ideas I would appreciate it. Thanks!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 7:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 9:16pm
i doubt you will find the correct taper off the shelf. I would buy a sprocket the size you want with a bore the size of the small end of the taper. Then have a machinist bore the taper to the desired size. Use the old sprocket to get the dimension for the machinist.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 9:23pm
Use your tapered hub. Grind/machine off all of the old sprocket. Weld on a new bare sprocket onto the existing tapered hub.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 9:24pm
Adam. Our local welding shop carries a large selection of products like that. You might check with one close to you
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 9:34pm
Would machining (or changing) the shaft to a straight shaft be an option?  Then you should have many more stock sprocket options? Not being in front of what you are working on to see what you are up to, this is just an idea.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 10:13pm
I agree with the good Doctor. Sounds like you have what you need in your hand. Cut off the old and weld on the new.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 4:21am
x2. if your unable to to the welding and such, just take the two sprockets to the welding shop and they'll change them.
Edited by dt1050 - 03 Feb 2018 at 4:22am
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 6:11am
I would go with the machine shop route, they will need the old hub to set up the correct angle I think.    Thirty min setup and five to cut the taper .
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 12:15pm
Adam....Look on the AC combines.  they used a lot of tapered shafts with cast hubs and removable steel sheaves....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 4:32pm
I'll check on an old allcrop we have laying around. The old sprocket broke into half a dozen pieces when it went so using it as a center would be hard to do. Trying to make the shafts a straight shaft would be difficult too. Grandpa had used parts of 2 12a john deere combines and their bins to make a feed cart decades ago, and though I don't need it, i don't want to part with it either so would like to make it usable. Thanks for the suggestions. I hadn't thought about a taper not being standard. That's probably part of why I can't find one... Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 4:36pm
Clamp the old tapered hub in a lathe and make it round again. Find a sprocket of the right tooth count and mate the two together.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 12:22pm
As the DR said:
Put the tapered hub/sprocket in lathe... cut off the sprocket.  Turn a concentric land, and fit a roller-chain sprocket in it's place.  You could probably face the old sprocket, and drill it to make the new sprocket BOLT on, which would save work and prevent distorting the new sprocket, and in the case that the hub is not-so-weldable, you're not welding it...
If you have the shaft, then collet the shaft into the lathe, and put the sprocket hub back on the taper, so it all runs true in-situ.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 8:08pm
And yeah, I'm probably seeming a little pushy in expecting that Adam would have a lathe...  No, Adam- if you did, I'm certain you would've either already done this, or asked how we'd set it up if we were...  but I'll bet that not too far from you is a tractor enthusiast that happens to have the machinery and ability to knock this out for 'ya, and not destroy a bank account doin' it.  If you were my neighbor, I certainly would...
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2018 at 10:31am
I'm thinking the old sprocket and hub may have been cast iron. Anyway, Adam said it broke into half a dozen pieces, so I think he meant the hub with the taper is broken up and therefore not re-useable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2018 at 10:57am
Phil is right. The sprocket, hub and all, shattered when it broke and it is cast. I do have access to a lathe, but don't have a good way to make a key-way if I did get the taper cut correctly. I was hoping to find something ready made, but doesn't look like that's likely. I appreciate the suggestions. I will dig around some other old machinery to see what I can find and keep it flat chain if I can, other wise I will probably have to start from scratch to build both sprockets to something more modern... Thanks again
