715 backhoe forward/reverse
FarmerBrawn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FarmerBrawn Quote  Post ReplyReply Direct Link To This Post Topic: 715 backhoe forward/reverse
    Posted: 01 Feb 2018 at 10:54pm
Have a 715 backhoe. Forward works pretty good when transmission warm but in cold weather does not want to lock up and only moves in reverse. I can get it to go forward but it is slipping. 4th gear has always slipped. 3rd won’t pull a hill.
I am assuming an overhaul will be in order.
What is the model so I can check with local guys to setup overhaul?
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 9:08am
Our 715 lost all gears but 2nd. Took it out and couldn't find the gears to rebuìld. Found a used one on craiglist for 500. Not a bad swap to do.
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 9:11am
Don't remember the make an model # on it. Should be a tag on the tranny.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 9:44am
Someone on here listed a kit for the clutch pack back when i was having problems - believe they were out of Michigan
 The fwd/rev clutch pack is bad - needs rebuilding R&R is suppose to be about 10 hours according to book .
 It's a common problem and one of items that needed repair . Fwd goes bad and reverse will still work some - and yes 4th and 3rd lose power to drive and the more its used the more the clutches wear and fail
 Ah yes - I needed my machine so had a Ford Dealer (Carleson Tractor of Rosemount MN) who said they could do it repair mine while i rented a machine from them to finish jobs i had - I had a spare parts kit from when i bought the machine so gave them my manuals and parts - (they are now out of business)
 Took them over a week to repair - charged me 40 hours labor + rental for transmission jack - said kit was short 3 "O" rings which they charged $80 for .
 Got in quite a hassle with their shop foreman - he questioned if my check was any good - I questioned his legal birth - but as they had my machine and i needed it I paid .
 Unit went bad again within 25 hours of use ( $4000 down the drain to crooks )
   Same outfit went after my oldest son for some bill they said he had - took him to conciliation court in 3 different courts - different counties - then here in Wash Co - judge here dismissed all charges with prejudice - told them he would recommend to my son to file harassment charges in District Court against the dealership and owners .
Edited by Coke-in-MN - 02 Feb 2018 at 9:58am
AC7060IL View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 10:30am
Yikes!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2018 at 5:45pm
The transmission is a Borg Warner 4 speed box - the fwd / rev unit is a hydraulic clutch pack with a torque converter in front - there are pressure rating measurements to help identify problems also in repair manual
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2018 at 7:30pm
We have 816 backhoe did ours twice since 78 if you have the book it is really easy
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2018 at 10:22am
I have a new shop manual for 715B s/n 2045 and up. $35.00 shipping included.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
This page was generated in 0.172 seconds.
