450 roosa on 301
Bobo Husker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobo Husker Quote  Post ReplyReply Direct Link To This Post Topic: 450 roosa on 301
    Posted: 31 Jan 2018 at 12:58pm
Attempting a 450 roosa on a 301. Having an issue with timing. If you pull the banjo bolt a look into port, two different holes pass by port approxamatly 60 deg apart. Which one is injection. Also is there a recommended degree, fuel should start at. Ive been told center of fuel injection should be 4 deg btdc.
Any advice would be greatly appreciated.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2018 at 1:52pm
post in pulling forum  you will get help there
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2018 at 6:11pm
UMMMM, you need to be timed on your crank , and the timing marks need to be lined up in the window , they aren't port injection timed
Edited by DougG - 05 Feb 2018 at 6:12pm
This page was generated in 0.091 seconds.
