Ca hold position.
Nathanb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathanb Quote  Post ReplyReply Direct Link To This Post Topic: Ca hold position.
    Posted: 28 Jan 2018 at 9:45am
I have an ca tractor that will lift the lift arms when hold positions lever is in down position and the lift arms will not drop anyway I move the valve. I disassembled the hold position valve body, but having trouble getting the plunger out of the valve body. Everything else is removed, detent ball and spring, position shaft, screw, spring and ball are all out. I feel as though this plunger is froze in. Any ideas how to get this unfroze and out?? Much appreciated!!
Nate
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2018 at 10:54am
Sandy Lake is very good at rebuilding those valves.
