Need help id a radiator
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Topic: Need help id a radiator
    Posted: 26 Jan 2018 at 8:18pm
I have purchased a couple of radiators. One is definitely a styled wc or wd. The other looks like an unstyled wc but the upper water neck and temp gauge are off set to the left side of center a couple inches when viewed from fan side. It has the allis chalmers stamped in the upper tank. Did some wc/wf have the temp gauge offset from the rad cap? I do not have any pictures at this time. Hopefully I can get some tomorrow. I have looked online and haven't seen a hood rad that has the temp gauge offset. Thanks
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 8:34pm
I have a '37 WC (unstyled).  Allis Chalmers on the top tank.  The temp  gauge is centered, directly behind the filler cap.  May not be the answer you're looking for but I hope it narrows down the possibilities.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 8:41pm
Show the dimensions also. Might be from a combine or pu
