FS, A,E -25-40. U & UC Parts
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Topic: FS, A,E -25-40. U & UC Parts
    Posted: 04 Jul 2010 at 7:44am
I am going to be adding to this list all day keep checking back .All these parts I list today can be taken along ( no charge)  to Ashland Show in Ohio July 9,10.  Thanks Fred
    Phone 717-451-6590 8 am to 9 pm
Pressure plate assembley A Rebuilt . $225.oo
Rebuilt Clutch disc early A small cluch shaft $125.oo  will sell as set $300.oo
Nice core heads (2) Very nice exhaust ports $225.oo each $400 pair
Front top cast  A gas tank support $75.oo
Good rocket shafts assembleys and push rods A,K ,25-40 ,e-60 P/U 2 shafts and 8 rods $50.oo
Oil pumps A , K ,25-40 , E-60     $50.oo
2 NEW 7.50 x 18 ,Kelly super high rib tires  $165.oo
Oil pumps U Uc  M crawler  $50,oo
Govenors UM engines complete good assembley $75.oo
Continental engine parts
Mains bering set  $50.oo
Upper &  lower pans ,front axle w/ engine support & axle  $100..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 7:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 7:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 8:06am
Clutch Plate pin support a pedal UC $35.oo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 8:08am
Late oil assembley K,A 25-50 ,e-60 ,L crawler   $45.oo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 8:16am
U,UC ,M crawler W /UM engine $ 75.oo w/ jar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 8:19am
A , 25-40 ,K ,e-60 Exhaust manifold $150.oo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 8:28am
Top hitch A ,U and Uc's  $25.oo cover plate $10.oo   $30.oo pair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 12:07pm
Air cleaner assembley A.25-40 ,K crawler ,E-60 P/U new bottom.No air tube to carb . $135.oo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 12:21pm
Spark plug cover . The top one is forsale it is a aftermarket one made off of ORIGINAL one ,witch is the bottom picture AND is NOT Forsale.
$60.oo for aftermarket cover
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 12:24pm
U & UC draw bar support .Has been welded where marked in yellow. $25.oo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 12:26pm
A gas tahk front bracket $75.oo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 12:30pm
A,K crawler,E 25-40  and E 60 P/U water pump pulley's . $75.oo each
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 12:33pm
crank pulley U,UC,. M crawler . UM engine. $35.oo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 12:38pm
Intake with very nice heat chamber ,ears off other manifold need to be put over on good one. $75.oo
Or would sell this intake with exhaust manifold listed above for $250.oo as a set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 12:39pm
That should as a set on manifolds for $200.oo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 12:45pm
Full set of timimng gears for U and UC continental engine ,
Crank ,cam and gov. drive gear.
Will post pictures later .    $85.oo for the set
Front crank pulleys( Flat  )for same engine. $25.oo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2010 at 7:17pm
UC clutch pedal and support are sold. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 7:29pm
U  Spark Plug cover SOLD!!    Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 10:22pm
New 7.50 x 18 tires          SOLD!!!!!!
       Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2010 at 7:20am
Oil filter .   SOLD!!!!!!   Thanks Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 9:02am
Water pump pulley's   for A's ,  SOLD!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 9:41am
The 2 core heads are now  availabe !!!!!!!!!!.    Thanks   Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 9:42am
That should   say  " NOT AVAILABLE "
