716 6 Speed Motor Upgrade
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: 716 6 Speed Motor Upgrade
    Posted: 26 Jan 2018 at 7:14am
I need to freshen up the 16HP Kohler Single in my 716 puller.  I was thinking of putting a Zach Kerber hi lift cam in it with the valve train kit he has to go with it.  Do you think this will be too much for the stock rear?  I will be having a look at the bevel gear box to make sure it is up to snuff, and will put a straight shaft in the transaxle.  Thanks!!!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2018 at 8:54pm
kind of unrelated  but do you still have the balance gearrs in side the engine ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2018 at 9:17pm
They are in there. Yes.
This page was generated in 0.215 seconds.
