"g" carb problems ??
wahl4m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wahl4m Quote  Post ReplyReply Direct Link To This Post Topic: "g" carb problems ??
    Posted: 23 Jan 2018 at 1:41pm
i rebuilt the carb -wouldnt start! installed one of another "g" -run good ! took both apart -& compared parts -ckd the mating surfaces ,floats & levels -cant see anything wrong ?? what am i missing ?any ideas ?? thanks mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 2:50pm
plugged passage way ?
gasket wrong way ?
it took me 3 'total tear down/clean/rebuilds' to get a CA hydraulic pump to run right...
sorry,had 3 Gs, have none now to eyeball what it could be...
jay
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 3:24pm
Yeah, every time I've cleaned carb, it took several tries before it was good.  Is it possible a gasket is flipped over and blocking a passage?
Edited by HoughMade - 23 Jan 2018 at 3:27pm
1951 B
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2018 at 8:58pm
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
should show all the carburetor assembly and tuning details.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wahl4m Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 1:15am
ckd all passages /gasket will  only fit 1 way w/ float-i chd surfaces for warpage -all ok ! guess ill take it apart again ?? thanks
drobCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 6:10am
I had what I guess was a stuck float on a brand new carb.
disassembled, found no problems, reassembled = works fine.
not the first time a take apart/reassembly doing nothing else has "fixed" whatever.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2018 at 8:08am
From my experience, the usual problem is a clogged jet, but I cleaned the carburetor on my son's G and it would still would not run.  When I pulled the carburetor apart a second time, there was no gas in the bowl.  The problem was the float valve sticking.  The valve was new, so I tried again and it did not work.  Finally found a used valve and installed it and the tractor ran fine.  Even new parts are not a guarantee.
