wd45 hand clutch seal
tom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom Quote  Post ReplyReply Direct Link To This Post Topic: wd45 hand clutch seal
    Posted: 03 Jul 2010 at 4:54pm
What do i have to do to remove the seal on the shaft going into the trans houding that controls the hand clutch. my 45 is leaving a tell tale path of oil every where so i can find my way home!! i just hope the bushes are not wore out.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2010 at 10:14pm
I've been lucky and never had one leak yet.
It looks like if you get the bolt out{#7} you can get the shaft out {#9} and replace the seal {#8}.
The seal should be available from an AGCO dealer.
Part # 70224644
Here is a picture that may help you.
Edited by Jeff Z. NY - 03 Jul 2010 at 10:16pm
