Winter project
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Winter project
    Posted: 19 Jan 2018 at 9:09pm
With the weather here in Michigan, just taking any time I can to take off parts, clean them up and be ready for a repaint of my HD16. Some pics of some of the pieces. Grill cleaned up nice and am adding 6" headlights.
Battery hold down bracket cleaned up nice and the cut off switch attached nicely to a piece of 3/4" oak painted to match.
Come on Spring.
Morten.have View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 1:32am
Looks really nice ! Is it the Cat yellow?
I’m happy to see that you did find a lens for your dashboard light šŸ‘šŸ»
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 6:41am
Thanks Morten.
Yes it is Cat yellow. Good eye. I made the lens cover from a glass bottle that I cut to fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 6:57am
Did you cut it with the string and lighter fuel trick ? ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2018 at 7:07am
A diamond wheel on a dremel rotary tool. Screwed up two bottles before I had a good one.
Now I just have to sort out the dash switch so it lights up. On yours I saw one of your earlier pics showing your dash light on.
The switch was in the vertical straight up position. Does your light come on when engine is running or do you have to turn the swtch to the left or right.
Thank you Morten.
This page was generated in 0.266 seconds.
