Mix your own PO #1?
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: Mix your own PO #1?
    Posted: 15 Jan 2018 at 4:17pm
I have the same dilemma as most of us. At $300/ gal for automotive quality paint, it's hard to justify the cost. I would like to paint my towing rig to match my tractors. Not looking for a show car finish, but not wanting to use something that will fade out and get chalky after a year.
Was standing in Runnings this morning looking at Majik brand tractor paint. Their paints use reducer and hardener. I know adding the hardener helps with the shine.
Now for the root of my problem. They only have Corporate Orange. Standing there looking at the color options, I was wondering if I took a gallon of Corporate Orange, added a little brown to get the right tint and a little white to lighten it, do you think I could get a close match to PO#1? Has anybody tried to mix their own. I know guys have mixed their own for Minneapolis Moline's yellow and had good results. Going with tractor paint it would cost me $45-50/gal vs $300/gal.
If anyone has tried it, I'd like to know how it turned out, and if they had some mix ratios.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2018 at 6:09pm
we had ppg 60080 put in spray cans  it cost 15.00  a can,       but it is handy and looks good and weathers excellant  so buying buy the gallon shouldnt be to bad   and no clear coat to fade off or peel
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2018 at 6:58pm
A good clear coat with UV stabilizer will stop fading for the most part. I mix most of the tractor paint I use with a tint to satisfy my color wanted.(Color Wanted)
Edited by Dick L - 15 Jan 2018 at 7:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2018 at 8:48pm
PPG 60080 is $300/gal. Any automotive paint with red in it is expensive. Rattle cans aren't full to the top. Have to leave room for the propellant. Plus it is half thinner. So you don't get much actual paint for that $15.
Edited by truckerfarmer - 15 Jan 2018 at 8:53pm
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 1:34am
I believe Orscheln Farm and Home has PO#1 if you have one close to you. They also have the hardner etc. to add to it. Haven't checked the price lately, but it was a lot cheaper than the other stuff. They're old paint wasn't worth squat, but that has been changed.
wayne IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne IA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 5:23am
Just a guess, but red would probably be better for trying to get orange to match PO#1 than brown.  A friend used a little yellow (very little) with a gallon of white to make a fairly good replica of the cream.  Using the hardener in the paint is what turns the enamel into an acrylic enamel which will resist fading better than the straight enamel.  If you're going to a clear coat over the top, make sure to use a test piece to verify that the clear coat is compatible.  It may blister and peel if it isn't compatible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 6:59am
Have not had good luck with rattle can paint. Usually gets chalky after a year or two. Plus it would take a lot of cans to paint the whole truck.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 7:08am
I can prolly get you the Valspar paint in the correct color. I painted the Kerosene C with it and some others, turned out nice for a fraction of the cost.
Edited by AJ - 16 Jan 2018 at 11:36am
Can't fix stupid
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 9:52am
Using valspar on my 45.  Looks good for now.  Time will tell.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 12:02pm
I don't see any reason why you couldn't mix your own from the same brand of paint.
I would suggest a couple of things:
1) mix all you think you will need and then some, in one batch.  That's the easiest way to ensure consistent color.  Then, as you measure out a quart at a time, add the hardener and reducer at that point.  Once you put the hardener in, you're on the clock.
2) If possible, mix the paint with a digital scale by weight and record how much of what colors (in weight) are needed to get the color you want.  This makes it much easier to replicate later than going by the comparatively imprecise fluid measurement.  Even then, however, you are counting on the manufacturer of the paint to keep the same, exact color.  When paint is not sold specifically for mixing, but to spray as it comes "from the can" you can't necessarily count on this.
I say go for it, and let us know how it goes.  From what i hear, Majic can work well if you do good prep, stick with light coats and make sure to leave at least 24 hours between coats.  Try to rush, either with the amount of paint applied or recoat times, and you will find horror stories.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 12:28pm
I just did a google 'ppg 60080' and got a LOT of hits.. there's NO reason why any automotive paint supply place can't mix it up for you. Since this IS your towing rig do it right,odds are you'll only have to paint it ONCE in your lifetime.
I'd go with either a single stage or base/clear auto NOT 'tractor' paint.
just my 2 cents worth...
Jay
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 7:11pm
I put valspar with hardner on my WD45 about 10 years ago looks as good as when I put it on. It holds up very well.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 9:15pm
At  local Lowes they can scan and mix po#1 Using Valspar Clear base tinting Enamel.
All you need to scan is a dry sample of PPG 600080. Comes out so close you can touch up PPG 60o80 with it.  get it mixed in Gals or Qts
Attwoods carries Hershall Adams Tractor paints,.  it is a gloss enamel . Saw one AC and G painted with off the shelf  H A AC PO#! and it looked absolutely PO#1 in my eyes . That is saying a lot. Nothing worse to wreck a decent RESTORATION than to paint the AC the WRONG shade of AC orange. Might as well paint it IH red
 Find Valspar clear tinting enamel where ever Valspar paint is sold. Local  ACE hardware for instance . lots of other paint outlets  around the country.
 I am still impressed with Hershall Adams PO#1 AC tractor orange. They also have PO#2 Not as pumpkin as PO#1, Too bright for any AC earlier than a D series after 1960  I believe.
Edited by Ken in Texas - 16 Jan 2018 at 9:59pm
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 9:22pm
i use ppg, dont want to use a cheap paint when i go through all the work of prepping the equipment. use a good epoxy primer and should be good foor a long time.
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 9:37pm
It's a $1000 truck, not a show truck. Just want it all one color after I get the dents and rust fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 9:51pm
Trying to avoid clear coat. Just gonna scuff it and shoot it. 1 and done. Ok maybe 2 coats. I used to paint dump trucks with one coat. Looked good with one coat. It's a work truck, not a show truck. Would like to use tractor paint for the durability. It's gonna get scratched! One gallon probably won't do it. Not gonna spend $400 on PPG just to get it scratched. Just like my tractors, it's not a trailer queen. I expect them to earn their keep.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 10:11pm
YOur on the right track Trucker... Do what KEN said. Take a sample of PO1 painted part to the store and have it scanned. They can mix to that color... Get something that you can pour the hardener in and it will dry in a couple hours instead of a month. You don't need the clear coat, just get a GOOD  enamel that uses the hardener.. I have painted a couple tractors / trailers that way to save some $$$ and it works fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 10:17pm
I have also done what you said for "mixed" colors.  I normally start with a couple ounces of paint  ( orange), then add a few drops of ( brown) at a time until I get the right color.. Keep track of the ratio.. When it looks about right, then mix a couple quarts and check color.... then do the whole gallon.... like mentioned, mix EVERYTHING you want to use the first time so the color will be consistant. ................ sometimes a pint / quart of red might be needed to get your shade, depending on the shade of the orange / brown original paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 10:20pm
If that was my truck I would go with
single stage PPG Omni Acrylic Urethane  in the ac orange that matches your tractors. No mistake about it . Any auto motive paint will outlast and outshine any cheap enamel money can buy.  Over the red on the truck now PPG single stage orange should go a long ways. Spot Prime any body work close to the sanded original color. Sand it all with 320.  Take a chance to save a buck by not prepping to finish paint with a full coat of sealer first.
 I primed a whole B with plain old orange enamel and finished with PPG Omni after several days of drying to sand the enamel very smooth and give it some tooth. One of the best PO#1 Bs to leave the paint booth ever.   My CA puller got the same kind of paint job in 2002. Still looks fresh and very nice 16 years later
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 7:10am
Few things in life match paint as to the old adage "you get what you pay for"  Nothing can be done to $35 a gallon paint  to make it anything close to $400 per gallon paint.   If left outside cheap paint is  going to fade and chalk.  Hardener helps as does doing a smooth job of applying it. Another factor is "good enough" for one person is "no way Hose" for the next guy.
Sooo, if the truck sits out it needs good paint unless  looking like a Orange cream sickle in a couple years doesn't bother you.
If it sits inside then decent service can be had from cheap paint IF it is applied right and hardened.  This C and B were both painted with tractor supply cheapo paint almost 15 years ago. Both are user tractors, neither has ever had a coat of wax but are kept reasonably clean. The C is Kubota orange, the B is A-C paint when they had it in the proper color, picture taken last summer.  The WD was painted wit PPG Omni about the same time and other then what we have knocked off of it in use the paint looks the same today as it does in the picture the day it rolled out of the shop.
Tireboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tireboy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 7:12am
I ordered a gallon of Persian Orange #1 from Yesterdays Tractor when it came it was Tisco paint. It goes on nice and the color isn't bad. Gallon part # is TP282gal ($46.89), Quart TP282qt ($20.58) and Rattle can isTP282sp but you have buy a case of six ($49.60). I went to my local Tisco dealer to order more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 7:38pm
I think for Tisco you better be adding some hardner.
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 8:56pm
While we are on the subject, when my inventory is gone I won't be selling any more paint. My AUTOMOTIVE GRADE Persian orange 1 (matches 60080) and 2 (matches 60396) acrylic enamel at $95/gal just can't compete with the Van Sickles, Tiscos or the homemade concoctions some are coming up with. Also, the $9 aerosol cans I fill myself will no longer be available once the inventory is gone. Thanks to everyone who has purchased paint from me in the past.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 9:59am
dont even think about tisco paint it will look so bad in a year  i know i have used to much of it the tisco,     cream color seams to be ok
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 10:21am
The biggest part of a good paint job is the prep it is hours of prep versus a couple hours to paint I use ppg paint the extra dollars are well worth the finished product that looks good and will outlast me
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2018 at 5:26pm
Haven't bought paint in a few years but last PPG 60080 I bought was OMNI for about $120/gal. Sounds like Deltron or Concept prices, those are way overkill.
Edited by Bill_MN - 27 Jan 2018 at 5:26pm
