1 Belt 2 tractor thrashing
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Topic: 1 Belt 2 tractor thrashing
    Posted: 14 Jan 2018 at 4:16pm
If you have never seen this set up over on Facebook on the Upper Midwest a-c club post is a picture of it running last July at the Orange Spectacular, it was built by Gary Agrimson and Gilbert Vust using pictures as a guide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 12:05am
I am wondering if anyone seen this last year at the show, and so what where your thoughts
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 5:25am
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 6:31am
Yes Darrell I saw it and looked close at it, Gary is a master machinest which I already knew since I have been to his machine shop in the cities. For those who may not know Gary has done detailed work for the medical industry. He showed me a machine he has that can "jet" a hole thru steel just a few thousands of a inch in diameter, much smaller than can be drilled.  Best of all he is a first class guy!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 6:45am
I'd think they'd 'fight' each other unless the PTO speeds were exactly the same ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 7:33am
Jay the key to get them to run smooth was matching up the rpms as close as possible and getting the govenors to work together
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 8:25am
I bet that was tricky!
What happens if they are out of sync?
-Ben
'39 Model B
Tractors are cheaper than girls, remember that!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 10:03am
The slower one out of sync starts contributing only load being shoved by the faster tractor and then the whole thing slows from the fast one being more overloaded by that shoving and the threshing machine load. Probably leads to speeds oscillating down and up.
I liked the Waukesha WC at Hutch a few years ago running the threshing machine, no complication and it ran smooth.
Gerald J.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 10:24am
My grand-dad used to run a 26"-er with a F-20 and a Ford-son the same way way and he never had trouble. The higher RPM tractor cared the load in tell the slower tractor started to pull. He used them that way for years because that's all he had to work with.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 11:32am
Gary is great. Didn’t know that about his shop, though. He’s very humble. When I asked him what all he did in his shop, he said, “Oh not much, just little stuff.”
I guess making a hole a couple thousands wide really IS “little stuff”. Lol
