How Do D-17 And D-19 Diesel Engines Differ?
180Puller View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180Puller Quote  Post ReplyReply Direct Link To This Post Topic: How Do D-17 And D-19 Diesel Engines Differ?
    Posted: 13 Jan 2018 at 4:55pm
Besides the turbo and exhaust manifold what are the differences between the D-17 and D-19 diesel engines??Are the D-19 injector tips bigger? If you had a D-19 diesel with a bad engine could you slip a good D-17 diesel in and use the turbo setup from the D-19? I assume that the 262 diesel and gas cranks are the same and also the blocks? I recently bought a rough D-19 diesel and I'm looking at options..
I'll show the rest of the tractor when I get it home..
Edited by 180Puller - 13 Jan 2018 at 5:06pm
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 6:48pm
No, I would not put the turbo on the D17 engine. The 19 had a lower compression ratio than the D17 and the 19's still had gasket /head troubles and then had updates on them and still weren't that super great.
  Would be better to just slip in a 262 gas motor...
Or find the 265 cu 180/185/190 gas or 2800 diesel motor, frame rails, front end and marry that on and have live hydraulics...
 Or put a 4BT Cummins in.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2018 at 7:05pm
late d17 diesel and d19 gas and diesel use the same block and crank
1968 D15D,1962 D19D
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2018 at 7:15am
Further to what Don said. The 262 gas and LP blocks, cranks, and sleeves are the same as the diesels. A few years ago we found a good gas block, crank , and used it to rebuild a late D-17 diesel engine.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180Puller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2018 at 8:07am
Thanks for the input...The reason I asked about putting a turbo on a D-17 diesel was that back in the early mid-1970's there were (4) D-17 AC diesel pulling tractors in my area....All had turbos and pulled the 5500 lb class and ran pretty good... They seemed to stay together and didnt blow head gaskets like the 460-560 IH diesels..I see that a D-19 is 14-1 compression and a D-17 is 15.7-1 compression..
I already have two D-19 gas tractors so kind of want to keep this one with a D262 in it..It would never be worked any,just a tractor to take to shows..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2018 at 11:37am
I have a later originally a combine gas block in in my early D17D. I fabbed a block off plate for the block mounted pump and put the original style head on it. Hard to say if the head gasket would hold boost with another 1 3/4 points. Much better fasteners are available today so maybe no problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2018 at 1:07pm
I  have always been very anti-D-19 diesel and claimed the sleeve lip (or lack of) was the problem. I looked up some sleeve specs and can tell you the 301 and 426 A-C engines had a lip of .094" to .095" and seldom is there ever a problem. The Buda wet sleeve engine lip was .034" to .035".  Mack says the fire rings are too soft, allowing the sleeves to start hammering against them and then things get loose real quick. He may be onto something BUT, the sleeve lip is sooooo small compared to the 301/426 engines. Even a D-17 gas was .108"  !!!!!  The Buda wet sleeve lip is fine as a gas engine, but a turbo diesel??  it's a breakdown in the making.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2018 at 10:43am
That was what I was thinking too. Not an easy job for a machinist to measure and do to measure and cut those counterbores. After I had done my engine, someone posted a link to an outfit in L.A. that made custom sleeves with wider flanges to combat that problem. The sleeves were standard width between each bore and elongated on the sides. I'm sure that takes a very proficient machinist to get that right, but I'm sure sleeve drop would be a thing of the past.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2018 at 9:18am
And to further that more lol, you have to remember that Allis engines were always diesel first, then gas and LP. More or less, the gas and LP engines (HARVEY, not West Allis) were built off of the diesel engine platform. Allis gas engines were way heavier built than they needed to be
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 3:57pm
That would be true for the 2000 and 3000 series, which were direct injection/open chamber type diesels. The G-230/G-262/D-230/D-262 were also built in the Harvey Plant, but were from the BUDA lineage which were the LaNova combustion chamber design, and were not a true A-C like the 2000 and 3000 series.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 6:33pm
Why did Allis carry over the Buda diesel lanova design? Was that just an inherited design? So Allis could get into the diesel market without developing the engine first?
Seems like once Allis engineered their own Diesel engines, things got better! Thoughts?
Galatians 5:22-24
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2018 at 8:17pm
In the mid 70's, I was at the Harvey plant and saw 2 6 cyl cylinder heads on a pallet. I knew they were smaller and shaped different than the 2800 heads - after some questions we found out they were used in testing a direct injection head for the D262.
The tests were ok, but the 4.33 (2200 turbo) engine proved better torque and hp at the same fuel consumption. At over 100 hp the d262 direct inj at the higher 16:1 compression showed much higher rod bearing wear over the 4.33.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 7:18am
The LaNova design was much less harsh on engine components than direct injection. In 1953 when the WD-45 diesel came out, it seemed almost everyone (except Detroit) was using the Lanova combustion chamber.  Direct injection/open chamber hammers on things much more than pre-combustion chambers do.
Alex (wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex (wi) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 7:20pm
What would happen if you put a D19 turbo on a late D17 Diesel engine?
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 8:05pm
put the turbo on a 262 gas
phil
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2018 at 11:16pm
If you do and don't mill the pistons down get a lot's of spare head gaskets and fire rings. lol
